Front end noise
Old May 7, 2017 | 10:08 AM
Ddibona's Avatar
Default Front end noise
I have a 2004 xj8 and every time I hit a bump, the front it sounds like plate clanking
Old May 7, 2017 | 03:21 PM
Fraser Mitchell's Avatar
Any odd tyre wear on the front at all, like on the inside edge of both tyres ? Is the general handling OK
It might be time to inspect the front lower wishbone trunnion bushes, especially the front ones. The fronts can get so bad that the wishbone arm can contact the subframe on bumps and braking.
Actually, I'd get all bushes and ball joints inspected !
Old May 8, 2017 | 10:19 AM
XJ8JR's Avatar
#1 easiest thing to check/replace first are the sway bar endlinks.
Old May 8, 2017 | 12:19 PM
Richxk8's Avatar
I had the same issue when I had a 2004 and it was the sway bar end links, very easy fix.
oldish git
23
Oct 7, 2016 11:01 AM
Eskr
Oct 4, 2016 11:42 AM
Apr 25, 2010 01:09 PM
Jan 9, 2007 04:21 PM
XJ40 ( XJ81 )
Dec 10, 2006 09:05 PM
