front wheel bearings
Old Mar 16, 2014 | 08:40 AM
talashek's Avatar
Default front wheel bearings
Has anyone replaced just the bearings in the front hub's? If yes, could you share the part number.
Old Mar 16, 2014 | 08:32 PM
Lagonia's Avatar
Hm, it looks like the bearing is sold as a unit with the hub according to JEPC. There are 8 different part numbers depending on whether it is supercharged and also depending on the VIN number of your car.
Search for JEPC in this forum.
Old Mar 17, 2014 | 04:38 PM
Bladevane's Avatar
Just replaced mine this weekend. They come as a hub unit complete with new wiring for the ABS. Mine were about £150 each. Job took about 7 hours in total - biggest problem was that the old hubs were seized in the vertical link. Had to use fox wedges and lots of penetrant/persuasion to get them to budge. Check whether you need a large Torx driver to remove 2 of the hub retaining bolts.
Old Mar 18, 2014 | 07:11 AM
talashek's Avatar
Thanks gentleman. I know that it it is sold as a unit. I have replaced both of my fronts. I was just wondering if anyone had replaced just the bearings. The bearings did not get there by magic. Thanks. 7 hours Bladevane....good grief, When I replaced the hub i removed the spindle and used a press to remove the hub. It took a lot of pressure and it sounded like a gun went off when it came free. I guess it's due to all the road salt that is used here in Chi town
Old Mar 20, 2014 | 06:23 PM
top140's Avatar
i have not replaced bearing but my mechanic has and yes you can get just the bearing. i got the national brand part #510099.
Old Mar 21, 2014 | 07:52 AM
talashek's Avatar
Top140 I see that bearing fits X we are talking about an xj8....correct?
PMKimpton
Aug 3, 2019 08:22 PM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
innzane
Sep 2, 2015 10:08 AM
