Frustrated beyond belief
Old May 20, 2024 | 05:18 PM
Brian M Williams's Avatar
Default Frustrated beyond belief
Ok guys, a while back I tried to install the Jaguar BT module in the trunk. Didn’t work and I pulled it. Then all 4 door speakers went out. I just ordered a salvage amp because I thought that was the problem maybe I blew a channel and installed it. Much to my surprise and dismay it not only didn’t correct the door speaker issue my Jaguar screen is now in Japanese. UGH..
Any thoughts?
Thanks,
Brian
Old May 20, 2024 | 07:10 PM
Default Ps….the amp I replaced it with was the same part number
Any thoughts?
Thanks,
Brian
The amp I replaced it with was the same number but is stuck in Japanese.
Old May 22, 2024 | 02:35 PM
got it out of Japanese. Now the door speakers are working, but you can barely hear the stereo. You can definitely hear the subwoofer. Any suggestions? Thanks.
Old May 22, 2024 | 05:35 PM
JoeDredd's Avatar
If you have the Alpine speakers then there is a very good chance they have been dying one by one and you have only noticed when the last one has failed. Pop a door card off and check the speaker for continuity, the wires corrode where they are in the melted plastic. You will see what I mean when you take one off. With your multimeter set on continuity put the probes on the pins in the connector, if you get a beep then you have a different problem, no beep then one or both wires have a break in them. You can solder a link wire in but the wire is usually that dirty the solder wont stick. A couple of mine look like a blind man with the shakes did them, but they do work.
Old May 23, 2024 | 06:35 PM
I checked the speakers out in the door. I took speakers out. Everything looks great no corrosion no nothing. Looks like a new speaker. I don’t know.
Old May 23, 2024 | 10:24 PM
h2o2steam's Avatar
Did you check the voice coil continuity with a multimeter?
Should be 4-8 ohms depending on speaker type fitted.
Old May 24, 2024 | 01:53 AM
ChrisMills's Avatar
My wife won't let me play (Pink Floyd) in the car.
She doesn't appreciate that I played the same tracks on my SII XJ6 back in the 70's. Oh, the history of the XJ...
Old May 26, 2024 | 09:18 AM
i don’t no how to do this. Audio is one area I’m not up on. Do you have a video of this?
Old May 26, 2024 | 04:09 PM
h2o2steam's Avatar
Just a generic Youtube video of someone checking a speaker with a digital multimeter.
You don't need to spend big bucks on a test meter, just get a cheap and cheerful meter from a car parts store, electrical wholesaler or electronics hobby store.
Old May 26, 2024 | 07:37 PM
https://www.youtube.com/watch?v=O6SLf6U7a9A
thank you. I really appreciated this. Buying an ohm meter now.
Old May 26, 2024 | 11:42 PM
ChrisMills's Avatar
Pretty sure that wiping an AA battery across the speaker contacts would cause some static noise.
Old May 28, 2024 | 05:16 PM
i cannot say thank you enough. Bought a voltmeter and they are dead as a door nail. Wow. All 4 at the same time. But I think you had a point that they were going and I didn’t notice until they died.
now…what do I replace them with?
Old May 29, 2024 | 08:13 AM
Jaroslav Záruba's Avatar
You can use the blue ones (Alpine) from X-Type, they're identical and should be easier to get your hands on. I have done the same.
Or if the circuit is broken on the (rather short) exposed part of the wire you could bridge it again.
I had all 4 speakers gone and only one of them could potentially be repaired this way, so I just bought a set of 4 from someone's X-Type.
Old May 29, 2024 | 11:48 AM
I found an old set of blue ones on eBay. Here’s hoping they work. 🤞
skywarrior
May 23, 2024 06:37 PM
samstagmoonyham
23
Oct 22, 2022 05:22 AM
crvols
Aug 11, 2017 09:02 PM
spielnicht
Jan 11, 2012 02:54 PM
qwiketz
Aug 4, 2011 06:38 PM
