Fuel Filter access problem
Old Nov 29, 2010 | 10:58 AM
oldmots's Avatar
Default Fuel Filter access problem
I tried to get to my fuel filter yesterday and two of the captured studs holding the plastic underpanel in place just spin in place, probably corrosion on the nut/stud causing it to break loose from the body pan. These nuts are deeply recessed into the plastic and difficult to get to. I would expect these to be fastened better but there it is. Anyone have experience freeing these?
Old Nov 29, 2010 | 11:56 AM
user 2029223's Avatar
Banned
Oldmots,
It happened to me exactly as you described. The fix proper fix is not worth the effort. So what you do is cut the underpan with a hole saw that fits around the problem nut/stud. This allows you to drop the underpan and replace the fuel filter.
Then put some Goop around the problem nut/stud to secure it so it won't rattle. Then secure the underpan with self tapping stainless screws and finder washers. Not too long, right? Problem solved.
Old Nov 29, 2010 | 01:10 PM
Fraser Mitchell's Avatar
Tarhealcracker
Very neat !!
Old Nov 29, 2010 | 01:53 PM
oldmots's Avatar
Originally Posted by tarhealcracker
Oldmots,
Great idea, I hated to take it to a shop and have them make a mess of it and charge me for the privilege. I'll do it that way, Thanks.
toronadomike
Jan 22, 2026 10:13 PM
Sprayall
May 30, 2021 08:13 AM
alpecsa
Sep 7, 2015 11:55 AM
bdboyle
Sep 4, 2015 06:16 AM
Sprayall
Sep 3, 2015 07:49 PM
