Fuel line hose remover # 303-623
Old May 11, 2017 | 10:59 AM
Wingrider's Avatar
Question Fuel line hose remover # 303-623
What are my other options? As Jag wants $30.00 for this small piece of (SH#T) metal.
Old May 11, 2017 | 11:15 AM
jackra_1's Avatar
Sealey Air Conditioning & Fuel Disconnection Tool Set 2pc | eBay
The above Ebay item is what I use.
located in UK.
I have had mine for many years and it has proven useful on many occasions.
Old May 11, 2017 | 05:43 PM
meirion1's Avatar
Does the Jag need 2 tools?
This does 3/8 and 5/16 tube?
Laser Tools 6822 Fuel Line Disconnect Tool | eBay
Old May 11, 2017 | 05:59 PM
Don B's Avatar
Your local auto parts stores probably carry the style of quick-disconnect tools that jackra_1 linked to. They may be packaged as "Ford" style tools.
Old May 11, 2017 | 06:49 PM
Wingrider's Avatar
Thanks for the answer, but do not see how this would release the clip on the fuel hose.
Old May 11, 2017 | 06:51 PM
jackra_1's Avatar
Only one tool is required and I was thinking at the fuel filter when I replied.
Where exactly do you want to release the fuel line?
Old May 11, 2017 | 07:28 PM
XJ8JR's Avatar
I picked up a simple set of plastic disconnect tools from Harbor Freight. If you're looking to disconnect the line at the fuel rail, I believe you need the 1/2" one. Don't be afraid to really pull at it (within reason, of course).
Old May 11, 2017 | 10:57 PM
Don B's Avatar
Search YouTube for "How to use fuel line disconnect tool" to see how these tools are used.
Cheers,
Don
Old May 12, 2017 | 08:04 AM
Wingrider's Avatar
Simple like most everything once you understand. Thanks for the info
Old May 12, 2017 | 05:25 PM
meirion1's Avatar
"Where exactly do you want to release the fuel line?"
Just thinking that I should have one for when my fuel pump runs out of puff.
Just need a spanner for my fuel filter?
Old May 12, 2017 | 08:24 PM
Wingrider's Avatar
Looking into what all is involved to change the intake manifold gaskets, or removing the intake manifold itself. Step # 13 detach the fuel line (310- 00) step # 6 detach the fuel line retaining clip.#7disconnect the fuel rail feed pipe spring lock couplings.
