gearbox fault - gearbox goes into limp mode
Old Feb 3, 2018 | 05:05 PM
Khb1's Avatar
Default gearbox fault - gearbox goes into limp mode
X350 Super V8 - My gearbox goes into limp mode, if i read gearbox date i come up with the following code; P1794 battery supply malfunction. If i watch data and watch the volts go up to 15.8 the gearbox light comes on. I have changed the alternator as I think its overcharging, but it still reading high. The fault is random and intermitant
Anybody got any suggestions, as I am completely out of ideas!
Old Feb 3, 2018 | 08:34 PM
pkoko's Avatar
How old is the battery? I would get it tested and if it is older than 3 yrs. I would replace it. This should fix most electrical problems.
Old Feb 4, 2018 | 11:46 AM
Khb1's Avatar
Hi Pkoko i have a new battery from what i have reserched these cars have a high charging rate of 15 volts If i have my diagnostic gear connected reading gearbox data i can watch power supply go up higher than 15 volts soon as it hits 15.8 volts gearbox warning light comes on and gives me a fault code of p1794 battery supply malfunction i have cleaned all ternimals on battery leads ect thanks
Old Feb 4, 2018 | 12:27 PM
pkoko's Avatar
15.8 is too high of a voltage... Can measure the voltage at the terminals? Measure with car off and on without load. Also measure it with electrical load with car on. It should be less than 15V; IIRC it should be 14.8V
Old Feb 4, 2018 | 02:07 PM
Khb1's Avatar
hi yes way to high but cant understand why it will creep up wirh no load and so intermittantbe think it might be an earthing problem or bad connection at ecu
Old Feb 4, 2018 | 03:35 PM
meirion1's Avatar
If the mechatronic plug is leaking (where the wires go into the gearbox) ATF can
contaminate the connections.
https://www.jaguarforums.com/forum/x...arness-106584/
Old Feb 5, 2018 | 06:52 AM
Khb1's Avatar
Hi meition gearbox plug oil and filter sump all changed by me using all gen jag parts all clean and dry thanks
Old Feb 5, 2018 | 01:32 PM
Don B's Avatar
Hi Khb1,
You have a real mystery on your hands, but I think with good methodical diagnosis you can figure it out.
First of all, the Electrical Guide and Diagnostic Trouble Codes Summaries will be helpful, and you can download them at the links below. You don't mention the year of your car, but the 2004 Electrical Guide is generally representative of all X350s:
Jaguar X350 Electrical Guide 2004
Jaguar X350 DTC Summaries Guide
Here's what the DTC Summaries have to say about P1794:
According to the Electrical Guide, the ignition switched power supply for the Transmission Control Module (TCM) arrives on a Green wire with Orange tracer stripe (color code GO), which connects to Fuse 33 (5 Amps) in the Passenger Junction Fuse Box (PJFB), which is located at the base of the right-hand (U.S. passenger side) A-pillar. Always-on battery voltage arrives on a Brown/Red (NR) wire from Fuse 17 (10 Amps) in the Front Power Distribution Fuse Box (FPDFB), located in the front right corner of the engine compartment.
You could start by measuring the voltage at the terminals in the socket for each of those fuses. Test Fuse 17 in the FPDFB with the key off. Test Fuse 33 in the PJFB with the key in position II (Ignition ON) but do not start the engine. Are the fuse spade terminals and socket terminals clean and free from any signs of whitish corrosion/oxidation? Do the fuses measure zero or near-zero ohms of resistance across their terminals? Is the voltage measured across the fuse socket terminals close to the voltage across the battery terminals with the engine off?
Another test would be to start the engine and measure the voltage across the battery terminals. Does the voltage rise to 15.8 volts, or is that possibly an erroneous value seen by the TCM?
The Workshop Manual Electrical section can be downloaded here:
Jaguar X350 Workshop Manual - Section 4. Electrical
You can download the other five sections of the Workshop Manual here:
X350 'HOW TO' quick links
Here's what the Workshop Manual has to say about Battery Charging:
You could also check the voltage at the TCM electrical connector. The ignition switched B+ voltage arrives on the Green/Orange wire, and the always-on battery voltage arrives on the Brown/Red wire from. Measure the voltage from those wires to ground with the key in position II. Turn the key off and measure from the Green/Orange wire to ground - if the resistance is low, there may be a short somewhere.
If you determine the charging voltage really is reaching 15.8 volts, I would suspect resistance somewhere in the circuit causing the ECM to read the voltage lower than it actually is. The ECM receives the alternator status signal over the CAN bus, so it can't be measured with standard tools. However, faults in the CAN may trigger DTCs with a U- prefix (Undefined, mostly Network-related). These are proprietary Jaguar codes that cannot be read by generic OBDII scanners, and require either a dealer-level diagnostic system such as Symptom Driven Diagnostics (SDD), or high-end third-party systems such as Autoenginuity with the Jaguar enhancement, or possibly some of the more powerful scanners from companies like Snap On, Mac, etc. If you can find a good independent mechanic with such a system , it would be helpful to know if any U codes are flagged since they may help narrow down your diagnosis.
Please keep us informed!
Cheers,
Don
Old Mar 6, 2018 | 03:05 AM
Khb1's Avatar
HI, Were on the same wave length as that. Have tested the voltage across the battery, and it corrosponds with the live data voltage when pluged into a scan tool. Im in the middle of checking all the earths at the moment, am using a Snap-on Solous Pro and have also read with a Lanch machine. Its so intermittent, some days its fine and other days it does it straight from start up. Sometimes it even seems temperature dependet (the car is kept in a garage) with colder weather making it worse. If i load the system up i.e with the heated rear screen on and the day time running lights on the voltage stays normal and i have no driving faults although the codes remain. Thanks for getting back to me, have only just seen this.. I have also recently read another intermittent code of B1676 in the drivers door module battery voltage out of range. When I have the ignition on the batttery light was pulsing and the interior lights, which makes me think that there is a bad earth or bad contact. I have only seen this once i have had this problem for over a year on and off. Thanks for the infomation.
Karl
Xtypematt
Mar 11, 2025 05:12 PM
Havafalcon
Sep 7, 2016 01:36 AM
davefowler
Dec 23, 2014 09:45 AM
MrJagXJ
Jul 22, 2013 11:02 AM
bretts1174
Oct 23, 2012 11:37 PM
