Getting to door handle
Old Jun 20, 2013 | 05:30 AM
kbeachy's Avatar
Default Getting to door handle
I have a 2004 Vanden Plas, and the driver's exterior door handle is starting to get a little loose. Does anyone have any advice on how to get to it? I expect it means removing the trim on the inside of the door, but I'm not sure where to start, what tools to use, and how the trim pieces are attached. I don't want to mar or strip anything by experimenting with prying here and pulling there. Thanks in advance for any help!
Old Jul 13, 2013 | 12:17 PM
3jags's Avatar
Have removed door panels and external handle on 1989 Majestic and 1993 Sovereign. Don't know whether comparable to a 2003 Vanden Plas but for my vehicles panel removal was easy once I figured out how the armrests were attached. Would definitely recommend buying the specialty upholstery tools -- I bought mine at Autozone. I started threads on this topic -- and handle removal -- you might want to check out the responses I got. Good luck
Old Jul 14, 2013 | 06:47 AM
kbeachy's Avatar
I appreciate your help. I bought the 6,300 page pdf service manual that also describes how to take the door panels apart, so that should be helpful too. Upon more inspection I've found that there is some play on the rear part of all the door handles, so I'm not really sure whether the driver's side is coming loose or not.
Old Jul 14, 2013 | 07:36 AM
3jags's Avatar
The Haynes Manual might also be useful.
Old Jul 14, 2013 | 06:25 PM
meirion1's Avatar
Loose handles are a bit of a fault on the x350.
Old Jul 15, 2013 | 05:13 AM
kbeachy's Avatar
3jags,
I haven't been able to find a Haynes manual for the 2004 VDP--do you have a link where one can be found?
That's helpful to know loose handles have been a problem on this model, so I'm not just imagining things!
Old Jul 16, 2013 | 01:23 PM
3jags's Avatar
Oooops! I had no idea Haynes were no longer publishing manuals for Jaguars. Mine are so old that the existing manuals cover them
Dz1rfj
Jul 17, 2018 10:29 AM
Col. Sandurz
Sep 28, 2015 12:49 PM
sadepol01
Sep 11, 2015 05:26 AM
1964Daimler
Sep 9, 2015 11:28 AM
hoodun
Sep 7, 2015 07:02 PM
