Hard reset
Old Apr 10, 2020 | 12:30 AM
Bigvettefreak's Avatar
Default Hard reset
I saw a post that mentioned a hard rest when having issues with warning messages for the air suspension. How do you do a hard reset? Thank you
Old Apr 10, 2020 | 07:56 AM
mhamilton's Avatar
Disconnect the battery and either let it sit disconnected for half an hour, or take the disconnected negative cable and touch it to the positive cable.
Typically air suspension faults are not going to be cured by this. The codes usually indicate a compressor not refilling the system within the time limit (leaks in the system and/or worn out compressor).
mick99
Sep 7, 2016 09:38 AM
Richxk8
Aug 15, 2016 10:49 AM
Anthony8858
Jul 25, 2016 11:06 AM
amitabhadatta
Jul 5, 2013 08:16 AM
pdog2000
Feb 1, 2012 10:39 AM
