Head Gasket job
Old Jan 8, 2018 | 02:56 PM
  #81
soceraz's Avatar
Originally Posted by jackra_1
Did you perform this operation before you took the heads off to minimize crankshaft movement when heads back on?
I lined up the cams so that the flat parts were on top, so that the special tool could be installed, before removing the crankshaft pulley. The pistons never moved after the heads were off. When the heads came off, No1 was not at TDC.
Old Jan 8, 2018 | 03:18 PM
  #82
BobRoy's Avatar
Originally Posted by soceraz
The manual (at least the part I read) states that you get number one to TDC and then install the special tool. This indicates that 1 should be TDC when the flat bits of the cam are vertical to the cylinder head. This was definitely NOT the case when I did mine.
Please let me know what manual you are looking at. Confirm what engine are you working on. I'm assuming you have a 4.2L V8.
Try this manual
http://www.jagrepair.com/images/Auto...0Code%20168.pd
The timing is 45° ATDC from a post from Motorcarman.
Old Jan 8, 2018 | 03:30 PM
  #83
soceraz's Avatar
Try this manual
I am looking at the Workshop Manual, the one that comes in 5 sections. The engine is the 4.2l from a 2005 XJ8L.
Old Jan 8, 2018 | 04:01 PM
  #84
BobRoy's Avatar
http://www.jagrepair.com/images/Auto...Code%20168.pdf
Link didn't work the first time. Motorcarman was kind enough to share it with us.
Look at page 26 of the AJV8 assembly section.
  #85
soceraz's Avatar
Bob,
The link to the manual didn't work.
Old Jan 8, 2018 | 04:08 PM
  #86
BobRoy's Avatar
Old Jan 8, 2018 | 05:34 PM
  #87
Wingrider's Avatar
Very nice
Old Jan 8, 2018 | 07:37 PM
  #88
soceraz's Avatar
Try this manual
Forgive my ignorance Bob, but how do I check that the crankshaft is 45 degrees ATDC? By looking at the flywheel?
Old Jan 8, 2018 | 08:30 PM
  #89
BobRoy's Avatar
You don't need to find 45° ATDC. This is where the timing is when the flywheel is pin and the cams are flat. My understanding is this position was chosen because you can rotate the cams and no piston is high enough for the valves to hit them.
Follow the procedure in the repair course manual.
Old Jan 9, 2018 | 10:07 AM
  #90
soceraz's Avatar
Bob,
The manual says "Prior to installing the camshafts, position the crankshaft to 45 degrees ATDC cylinder 1A"
If my camshafts need to be re-installed, wont I need to position the crankshaft at 45 ATDC for cylinder 1?
Thanks, Mark
Old Jan 9, 2018 | 12:27 PM
  #91
BobRoy's Avatar
All you need is to have the flywheel locked. That will give you 45° ATDC. There are no timing marks anywhere to check this.
You would need several instruments that you would find in an engine shop to check the exact timing, but it will be 45° ATDC.
Old Jan 9, 2018 | 12:57 PM
  #92
soceraz's Avatar
Ah, got it! Thanks.
Old Jan 9, 2018 | 01:56 PM
  #93
jackra_1's Avatar
BobRoy you have lost me here completely.
Are you saying that no matter what position the crank is in it will be 45° ATDC?
That just cannot be so.
Old Jan 9, 2018 | 02:32 PM
  #94
NBCat's Avatar
If the Crankshaft Holding Tool is inserted in place of the crankshaft position sensor, it will only fit into one opening in the drive plate correctly. Thus is the correct crankshaft position achieved.
Old Jan 9, 2018 | 02:39 PM
  #95
BobRoy's Avatar
When you put the tool into the hole the crank position sensor was in and there is a hole in the flywheel that the tool will fit into. There is only one of these holes in the flywheel that the tool will fit into. When these holes, crank position sensor and the hole in the flywheel, are aligned the engine is at 45° ATDC. You don't need to know that the timing advanced
Old Jan 9, 2018 | 02:43 PM
  #96
jackra_1's Avatar
Okay now I understand. Thank you.
Old Jan 9, 2018 | 02:44 PM
  #97
NBCat's Avatar
Care must also be taken to install the VVT units in the correct position when aligning the camshafts with the holding tool across the flats.
Follow the instructions in the Workshop Manual.
Old Jan 9, 2018 | 03:22 PM
  #98
BobRoy's Avatar
FYI.
From Motorcarman on the X308 site.
Attached Thumbnails Head Gasket job-tc_drive_plate_timing_8d695c14840b1ba6a379cc5b4ef04398299959ba.jpg
Old Jan 9, 2018 | 04:11 PM
  #99
soceraz's Avatar
It took a while for the penny to drop for me too!!!
Thanks for the explanation Bob.
Old Apr 18, 2018 | 09:16 PM
  #100
soceraz's Avatar
update:
It's been a while, here's the latest....reset the timing properly by pinning the flywheel and having the cams flat bits on top. Just finishing up torquing one of the pulleys and I noticed a small piece of plastic on a ledge. Instantly recognizable as a large piece of a timing chain guide. Aaaaaarrgggh. Took everything apart again, put a new timing chain guide on. Had a leaking transmission cooler line, after an epic fight managed to McGiver it so there was no leak. Started the motor and alas, it still runs like a pig with misfires on all cylinders. Did a compression check on two of the cylinders, one was 105 and the other 120. I'm thinking it's time for a new engine.
