headlight troubleshooting
Old Oct 31, 2020 | 01:05 PM
yellowbandit's Avatar
Default headlight troubleshooting
Okay. So - I purchased this car recently and the passenger side headlight was full of rusty water. The high beam lit though. The driver's side unit lit fine, bit was extremely hazy, so I replaced it also.
I found replacement headlights on ebay. The new one for the driver's side is fine, but the passenger side low beam still won't light. I've tried the old driver's side unit on the passenger side (had to turn the connector upside down, bit it fit fine), and it still doesn't light the low beam.
The question is this: what's left to replace? I was concerned the connector had rust issues, but I've spent a decent amount of time cleaning it and I suspect it's okay.
Old Oct 31, 2020 | 11:39 PM
I've been thinking about this. An electrical component plus water = a blown fuse. That's what I'm checking first thing in the morning.
Old Nov 1, 2020 | 12:57 PM
That was it. New fuse. All lit.
Whew!
Old Nov 1, 2020 | 01:40 PM
jerry_hoback's Avatar
Thanks for posting the result. My suggestion would have been a relay at that lamp.
Old Nov 1, 2020 | 01:44 PM
It'd appears I'm not quite out of the woods.
Now the headlights won't go off!
Sigh.
Edit: it's the high beams that aren't going off.
Old Nov 2, 2020 | 07:27 AM
Wingrider's Avatar
Both or just the passengers side ?
Do the brights go out with the switch when running ?
Old Nov 2, 2020 | 09:57 AM
High beams are always on for both sides. Whether the car is running, or not running with the key removed. I ended up pulling the headlights back out for fear of draining the battery.
I was going to purchase a replacement stalk on ebay, but I'm thinking it could also be a bad relay somewhere?
What do you think, Wingrider?
Old Nov 2, 2020 | 01:09 PM
Wingrider's Avatar
Water and electricity are a bad mix.
Try tracing the wires, from connection to connection.
Check for voltage & for burnt connectors
The wiring diagrams are available on site for free.
Old Nov 10, 2020 | 09:09 AM
OnebadassXJR's Avatar
No Need to replace if the lights are fogged or hazed.
Old Nov 10, 2020 | 01:27 PM
Wingrider's Avatar
Looks great, nice work!!!
Squireg33
Aug 11, 2021 02:56 PM
MJB1221
Apr 3, 2021 10:59 AM
Lord_Eduard
Sep 1, 2020 10:35 AM
Aarcuda
20
Oct 1, 2019 10:45 AM
jomo
Jun 26, 2016 08:09 PM
