headliner help please need info asap
need to replace my headliner as it has begun falling a part. Would anyone know where I can get the material from at a good price (im looking to do alacantara) and how much material would I need to do everything?(a-b-c pillars sunroof the works? thanks chaps....
About 6 yards. There are companies online that sell the material, make sure it is UV rated so it does not fade in a few months. The most important thing is to use the correct adhesive so it does not fall apart after a year or two.
I plucked this one off one of the headliner threads here on the forum a year or two ago whilst doing some research on headliners. Have neither order from nor otherwise dealt with them, but somewhere here there is a tutorial on an X308 and I believe whoever did it used this company, though I may be mistaken:
Your Auto Trim Store
I did this job on my old Range Rover a couple years ago. I'll see if I can dig up the link for you.
Just go to joann fabrics or any online retailer that sells the foam backed suede headliner material. Then go to Home Depot and pick up a can of 3M Super 77 spray adhesive.
JoAnn sells headliner material?
I can not speak from experience but I can mention 2 things I have seen on other forums regarding DIY headliners: 1. NON-UV rated fabrics fade to funky colours over time when exposed to sunlight, one such case I saw a young man changed his headliner to black suede he bought at a fabric store and in a year it had turned brown/orange. 2. If you do not use the correct adhesive, over time the headliner will sag faster than the factory one will. There is headliner adhesive available at a small cost, in fact the website mentioned a few posts up sells everything you need.
I'll be getting some from them for my XJR before too long.
wlsheadliners.com
Cheers,
bydand
Sep 28, 2015 09:47 AM
bydand
Sep 27, 2015 12:00 PM
BlacXJRcat
Sep 25, 2015 06:43 PM
