Heater issues
Old Oct 4, 2019 | 03:36 AM
Hsmmo61's Avatar
Default Heater issues
Hi everyone
My Jag XJ 2004 SE 3.0 V6 has cold air coming out of the driver side vents but passenger side is only just warm , car temp gauge runs at normal but does seem to get up to full temp very quick, anyone know what I should look at to solve this issue .
Andy.
Old Oct 4, 2019 | 06:23 AM
Wingrider's Avatar
Valve by the heater core that controls the coolant flow tends to plug up.
Had to replace one on an S Type with a six cylinder, it took a few hours.
Not all that bad a job, worst of it is the coolant drain, fill, then putting covers etc back on.
Old Oct 4, 2019 | 09:08 AM
Brutal's Avatar
A 2004 xj does not use the heater control valves like a stype. You need a new heater core. Its plugged i posted pics of mine when i replaced it last year and that was after a few flushes when i bought the car and that was a failure because she never flushed the cooling system.
Old Oct 4, 2019 | 03:10 PM
Wingrider's Avatar
My mistake, thought the sixes had the all had the same set up.
Plugged at the same place though, wonder if they would plug if the coolant was changed every three to five years???????
jaguars4r
Dec 29, 2018 01:03 PM
petemohr
Feb 28, 2014 08:08 AM
QuikCat
22
Jan 22, 2014 04:48 PM
JB Young
Jan 6, 2014 08:38 AM
jmault
Mar 20, 2013 03:44 PM
