Help with generic code P0174
Old Feb 8, 2015 | 03:52 PM
Britrover's Avatar
Default Help with generic code P0174
MY 00 XJR is now throwing P0174 generic code with detail ' system too lean bank 2'. I reset it with my scanner and it keeps coming back and the dash also reflects restricted performance. Does anyone have any pointers on what might be causing this so I can get ride of this irritating code?
Old Feb 8, 2015 | 03:55 PM
Britrover's Avatar
Mods please move this to the correct X308 group. My apologies for posting in this section by mistake.
Old Feb 8, 2015 | 06:08 PM
cjd's Avatar
cjd
Typical stuff...
Leak in the side 2 exhaust.
Injector clogged or with a bad connection bank 2.
Leak in the intake manifold on the bank 2 side.
If it eventually starts showing a P173, then it is something that affects both banks, so you can throw in..
Vacuum leak.
MAF dirty or bad.
leak in the intake tract.
PCV valve bad.
Sometimes a hose gets pulled and it's a small enough leak that it only shows one bank. If anyone has worked on the engine recently, check that area for something that got left off.
clubairth1
30
Sep 3, 2025 04:38 PM
nonfinito
Nov 20, 2015 09:57 AM
John Fox
Sep 19, 2015 07:56 PM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
