High Beams/Main Beams Issue
Old Feb 6, 2010 | 08:28 AM
tvn300's Avatar
Default High Beams/Main Beams Issue
2007 VDP issue with headlights. Low beams (dipped) work. Pulling the stalk back will "flash" the high beams (main beams), so I know the high beam bulbs are good. But when I push the stalk forward so that the high beams are supposed to stay on, I get nothing. Fuses seem ok (and the fact that they will light on the "flash" setting would suggest circuitry is all ok). So I'm thinking maybe the switch itself has gone bad. Any thoughts here?
Old Feb 6, 2010 | 08:30 AM
tvn300's Avatar
In re-reading this, let me clarify: When I push the stalk forward to the high beam setting, the high beams do not come on, but the low beams are still working. Sorry I did not include this important piece of info.
Old Feb 11, 2010 | 06:09 PM
hlgeorge's Avatar
You might want to check the relays in this circuit.
Old Feb 12, 2010 | 09:27 PM
papajag's Avatar
Ditto on checking the headlight control relay!
Old Feb 13, 2010 | 07:48 AM
tvn300's Avatar
Just to close the loop on this thread: took it to the dealership and they found the stalk to be bad. Replaced it and magically the fog lights started working again, too. Thanks for everyone's thoughts and help!
Wolfy
May 28, 2024 08:06 AM
afterburner1
Dec 16, 2015 12:12 AM
redrover41
23
Sep 25, 2015 01:33 PM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
