hood latch issues 2004 XJR
The hood latch is broken at the latch end of the device I have removed the wheel and the inner lining. But with all the piping and heat exchangers in there, I see no way to acces the latch.
any suggestions? I don't think it is even possible to get the front bumper off without the hood open????
Hi there
Get under the car undo the platic covers carefully , the first one behind the fontlip has another plastic construction above it to lead the air to the coolers . Take that one out then you will be able to see and reach the locksystem right and left as well as the latch system
Thanks for your help.
I was able to access the hood latch from underneath after removing the front spoiler and plastic cover.
I slid a 2'0'' or so piece of flat steel up there and was able to op-en the latches by tapping the piece of steel with a hammer...what a pain in the hiney!
