hood latch issues 2004 XJR
Old Feb 19, 2021 | 02:00 PM
David T.'s Avatar
Default hood latch issues 2004 XJR
The hood latch is broken at the latch end of the device I have removed the wheel and the inner lining. But with all the piping and heat exchangers in there, I see no way to acces the latch.
any suggestions? I don't think it is even possible to get the front bumper off without the hood open????
Old Mar 1, 2021 | 11:57 AM
Petz's Avatar
Hi there
Get under the car undo the platic covers carefully , the first one behind the fontlip has another plastic construction above it to lead the air to the coolers . Take that one out then you will be able to see and reach the locksystem right and left as well as the latch system
Old Mar 1, 2021 | 12:01 PM
Petz's Avatar
Just undid and fixed the plastic covers by glueing and exchanged all the screws .While doing that I had a closer look at those from underneath and thaught of answering your post
Old Mar 1, 2021 | 06:37 PM
David T.'s Avatar
Thanks for your help.
I was able to access the hood latch from underneath after removing the front spoiler and plastic cover.
I slid a 2'0'' or so piece of flat steel up there and was able to op-en the latches by tapping the piece of steel with a hammer...what a pain in the hiney!
mikebaker3
Jul 21, 2016 01:22 PM
oldpunk
Mar 28, 2014 03:39 PM
xk82006
Sep 8, 2012 11:46 PM
deadboy1977
Apr 27, 2011 07:31 PM
Gus
Sep 4, 2010 05:10 PM
