How difficult to swap engines in 2004 XJR
Old Jun 20, 2020 | 10:54 AM
Fitz's Avatar
Default How difficult to swap engines in 2004 XJR
The engine in my XJR is shot. I found a replacement, but it's going to cost about $2000 in labor to do the swap. I have swapped engines and trannys back in the day, and have done most of the repairs on this car, so I have tools and a fair amount of mechanical ability. I have more time than money, so it might be worth spending 20-30 hours doing this project. I will be replacing hoses and gaskets before installing the new engine.
Can anyone provide their experience/wisdom on performing the engine swap? Am I going to get in over my head?
Old Jun 20, 2020 | 12:55 PM
Fraser Mitchell's Avatar
If you're just swapping a bare engine that is the same as the one that's shot, and transferring all the old ancillaries and electronics over, you shouldn't have too many problems. Trouble starts when people put in electronic stuff related to the engine that then needs matching to the car, and the use of factory electronic programmes.
Old Jun 20, 2020 | 01:48 PM
Fitz's Avatar
Thanks Fraser. I am installing the same stock engine from the same year and model. Same 8th digit vin.
Old Jun 20, 2020 | 02:01 PM
motorcarman's Avatar
Probably the easiest/safest way is to remove the gearbox, then pull the engine. Install replacement engine and then the gearbox.
If you have a car lift you might try to drop the subframe and engine/trans as a unit onto some hydraulic tables with wheels.
bob
Dhighlife27
Oct 13, 2016 02:14 PM
OUScooby
Aug 23, 2016 03:03 AM
XJsc-guy
Jun 14, 2015 03:49 PM
skanoski
Aug 13, 2012 05:40 PM
SoTxXjr
Nov 21, 2009 04:07 PM
