How do you remove the console with rear a/c controls in the Vanden plas 2005
Old Jul 21, 2022 | 09:24 AM
JDog's Avatar
Default How do you remove the console with rear a/c controls in the Vanden plas 2005
Hello Everyone:
Has anyone removed the console on a 2004-2007 vanden plas WITH the rear seat control for the A/C? This is not like the regular console. It has a A/C evaporator coil inside the console. WTF
Help
JDog
Old Jul 21, 2022 | 05:24 PM
yellowbandit's Avatar
Try this.
ht​​​tps://www.jaguarforums.com/forum/xj-xj6-xj8-xjr-x350-x358-28/removing-console-x358-shallow-cubby-231356/#post2218363
Old Jul 21, 2022 | 07:25 PM
JDog's Avatar
Thanks so much. This really helps. Is the arm rest hinge attached to the ac unit?
JDog
Old Jul 21, 2022 | 07:29 PM
No. Attached to the console itself. There's kind of a support structure in there.
Old Jul 21, 2022 | 10:30 PM
JDog's Avatar
Thanks YB:
Do you have to charge the console unit with freon or R22 or 410a? Or does it charge from the main ac unit?
JDog
Old Jul 21, 2022 | 10:53 PM
Sorry. No idea. Someone else will probably know. I imagine it's a separate system though. I could ABSOLUTELY be wrong about that.
Old Jul 22, 2022 | 12:00 AM
pkoko's Avatar
Originally Posted by JDog
Thanks YB:
JDog
The car only has one AC compressor so the refrigerant has to be shared across multiple evaporators. My only explanation is that rear AC unit exists is to have some control system to regulate refrigerant flow to the rear evaporator to control the temperature for rear passengers. Thus the need for an additional evaporator. Got any pics that you can share?
Old Jul 23, 2022 | 08:46 PM
JDog's Avatar
Thanks so much to everyone. I took off the console in record time. I had to fix the arm rest and could not do it with the console in the car.
JDog
banar
Dec 7, 2023 06:18 PM
JFNAKI
Dec 11, 2019 10:45 AM
ragman1171
May 24, 2016 11:30 PM
socalwinegirl
Oct 2, 2014 12:11 PM
