How to electronically disable starting the engine
Old Jan 25, 2013 | 05:39 PM
GrafShutka's Avatar
Default How to electronically disable starting the engine
Does anybody know the easiest method to electronically disable anybody starting your engine even if they have your car keys?
Is there a single fuse in the fusebox which can be removed when you park your car in a less than salubrious part of town?
In the old days, it was easy, one just put a little piece of cardboard in the distributor cap to disable the engine from firing up,
Old Jan 25, 2013 | 08:39 PM
Jag XJ8 Red's Avatar
Banned
There are any number of relays or fuses you could pull. How would they get your keys short of a hijack?
What car?
Old Jan 28, 2013 | 12:05 PM
karl_s's Avatar
Not 100% sure this will work as I have not tried it.
At the ignition switch you "could" cut the Red/White wire (IP34-5) and splice in a hidden switch. Its the Key sensor for the Passive Anti Theft System. (see schematics fig 2.2). Idea is the Passive Anti Theft System doesn't see it has a key inserted and so never reading the keys chip thus never giving the OK to start.
Old Jan 28, 2013 | 01:56 PM
Banned
The OP asked a question and hasn't logged on since. Wow.
Old Jan 29, 2013 | 04:39 PM
GrafShutka's Avatar
Default I was offline
Sorry, I've been offline.
The car in question is 2006 XJ8 VDP.
The problem is to avoid somebody who hijacks your keys from driving away with your car.
This could be simply swiping the keys from your desk when you are not looking (Option a) or even a carjacking in the street (Option B).
For the latter case, you would need a separate electronic switch in your pocket which needs to be "activated" to restore a suitable electrical connection to enable the engine to start.
The question is what is the best "suitable" electrical connection for Option A (static and manual) and Option B (real-time and wireless trip) ?
toronadomike
Jan 22, 2026 10:13 PM
Sprayall
May 30, 2021 08:13 AM
tberg
Sep 7, 2015 07:32 AM
Sprayall
Sep 3, 2015 07:49 PM
TC Johnson
Sep 2, 2015 09:30 AM
