How to get the head rest back on?
Old Jan 10, 2023 | 10:51 PM
TommyBoah's Avatar
Default How to get the head rest back on?
Hello everyone,
I had to take my headrest out for some spacing to do several projects on the rear shelves, and now comes the time to put them back on.
I managed to put the one on the passenger side back on normally, but I couldn't put the one on the driver side back on; it feels like something is blocking its way back in, and I've tried everything I can such as brute-forcing, wiggling it back and forth, making sure nothing is obstructing the path but it still refuses to go back on.
Any ideas or suggestion will be greatly appreciated
Thank you.
Old Jan 11, 2023 | 01:16 AM
FreeWifi's Avatar
The button to press in to adjust the headrest is circled in red. It looks like the right side of the headrest is higher than the left and may be jammed. Could just be the angle of the picture. But you should be able to push in the button and lower. If it is stuck and the left is lower than the right side I would try holding the button in and give it a firm wiggle up and down on the left side to even the height before trying to lower again.
Old Jan 11, 2023 | 11:13 PM
TommyBoah's Avatar
Appreciate your answer, I'll try it and let you know if I managed to get it back in.
bobson2
44
Jan 27, 2023 06:29 PM
LnrB
Mar 27, 2022 05:18 PM
brian2891
Feb 4, 2022 08:02 AM
sidescrollin
Jun 7, 2018 02:03 PM
Benhamtroll
Jan 23, 2014 05:36 PM
