How to remove trim above the doors
Old Nov 21, 2011 | 11:08 AM
MTW's Avatar
MTW
Question How to remove trim above the doors
I am replacing the chrome trim on the roof above the doors -this runs from front fender to the rear fender. My trim had been scratched by previous owner - properly big rings and holding on to the roof when getting in and out of the car.
I would appreciate if a Tech or someone that has replaced this trim/molding could explain how this is removed? When I lift up the rubber seal towards the roof surface I can see some plastic clips - can these be pulled out and hereby release the trim? - maybe it will be more clear when I get the new trim/molding.
Thank you in advance
Martin
Old Nov 21, 2011 | 08:23 PM
jahummer's Avatar
Towards the end of the first post you will find links to download the service manuals, in there you will find the instructions you seek.
https://www.jaguarforums.com/forum/x...k-links-20085/
Old Nov 22, 2011 | 10:55 AM
MTW's Avatar
MTW
Thanks jahummer.
These service manuals could/will be sooo useful - never knew they were there -thanks.
Unfortunately it does not appear like the manuals describe anything about the moulding/trim on the roof?? - door and window trim is described but not the chrome roof trim (gutter). My wife says frequently that I am blind but I looked through the body and paint part multiple time with no luck??
Martin
Old Nov 26, 2011 | 07:50 PM
MTW's Avatar
MTW
Got the trim - damn it came without the clips - fortunately the local dealer has the clips. The clips are made to break as you are breaking the trim loose so these should be replaced with the trim - no way you cannot break the clips so make sure you have the clips before you take off the trim. This is something everybody can do - Gaudin jag in las vegas had the trim for 260 - not cheap but these pieces never are - local dealer wanted 390.
Old Nov 6, 2012 | 10:56 AM
Barryself's Avatar
Default help
how did you get the mouldings off? and how did you install the new ones on.....
Old Mar 9, 2014 | 06:37 AM
solartecromania's Avatar
I have pretty much the same problem but in my case it is the rear door trim moulding, not the long one which comes from the front on the roof, see attached pic. This part is in really bad shape, as I figured out it is not chromed, it is anodized aluminum.
How can I disassamble this part? There is no description in the workshop manual.
Regards,
Roland
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
AL NZ
Sep 4, 2015 08:39 PM
