Ingress/Egress not working properly.
Old Jun 5, 2019 | 03:00 PM
OnebadassXJR's Avatar
Default Ingress/Egress not working properly.
Used to work fine. Yesterday opened the door heard a click from steering column (moved a hair) same for the seat? Anywhere to look? Thanks in advance.
Old Jun 6, 2019 | 08:09 AM
Not one Guy on here has had this issue??
Old Jun 6, 2019 | 08:56 AM
Mark in Maine's Avatar
The only issue i've had is that when i moved the seat all the way back to clean, it confused the module of being out of range and froze up. Cycled the seat front to back and all was well. Can you move the column with the switch? That would rule the column motor out.
Old Jun 7, 2019 | 07:59 AM
Wingrider's Avatar
OnebadassXJR asked;
Just lucky i guess
Mark in Main's question is a starting point.
Old Jun 7, 2019 | 08:06 AM
I had it on auto. All other systems work from switch, but the auto locks up.
Old Jun 7, 2019 | 08:35 AM
Wingrider's Avatar
I never use the auto setting, prefer things stay where i left them.
Motors, as well as switches, do wear out, then things can get real complicated.
Leaving well enough alone, when things are well, is my way.
w.neurauter
Mar 22, 2026 12:17 AM
Sentinelist
Mar 17, 2016 03:05 PM
BoHoTom
Oct 10, 2012 06:02 AM
TxJag2004
Nov 16, 2010 08:12 PM
rajinder75
Oct 14, 2008 10:42 AM
