iPhone compatibility
Old Mar 21, 2025 | 01:30 PM
Guernz's Avatar
Default iPhone compatibility
Do current iPhones work with the factory Bluetooth system?
Old Mar 21, 2025 | 03:28 PM
Thomas-S.'s Avatar
There are different versions of the factory bluetooth system. Only the latest one is supposed to work fine.
As my car did not have bluetooth I retrofitted this version and there are no problems with my iphone 8. I have not tried out later versions yet.
The module number of the latest version should be 7W93-10D893-AB. It is located behind the left trunk cover, underneath the navigation module.
Best regards,
Thomas
Old Mar 21, 2025 | 04:21 PM
Guernz's Avatar
Best regards,
Thomas
Thanks for your reply Thomas. It looks like this part number is for the x type judging by eBay listings. Is it also compatible with the XJ? I thought the module part number ending in AC was for the XJ.
Can anyone direct me to the best thread on retrofitting Bluetooth and voice control? I know there are several threads on this, but none I have seen have been very thorough.
Can anyone give me a list of the required parts for the retrofit for US Bluetooth and voice control?
Also would be interested in hearing if anyone has experience with pairing newer iPhones.
Old Mar 21, 2025 | 04:49 PM
Thomas-S.'s Avatar
The part no. I gave you is correct, I remembered that I took pictures when I retrofitted bluetooth to my SV8, as my car is from Sept. 2003 and did not yet have bluetooth, only the integrated one that needed a separate SIM card.
So yes, it fits the XJ.
Best regards,
Thomas
Old Mar 22, 2025 | 05:27 AM
eliotb's Avatar
my 2006 VDP worked just fine with whatever iPhone I had at the time. Sadly, that car is no long with us. anyway, it worked fine.
Old Mar 25, 2025 | 09:40 AM
wfooshee's Avatar
The Jag Bluetooth is calls only, not music streaming, if that's what you're looking for. Something aftermarket if you want to stream.
Old Mar 30, 2025 | 11:18 AM
cornponious's Avatar
I have a 2004 Vanden Plas and my iPhone 10 works flawlessly with the Bluetooth.
Chieftan
Aug 12, 2023 09:05 PM
yeldogt
Nov 8, 2016 11:05 AM
XJ8JR
Jul 31, 2015 06:13 PM
Unk
Mar 6, 2015 03:49 PM
steelman3
Sep 23, 2014 09:45 AM
