Jaguar Voice
Old Oct 29, 2014 | 11:49 AM
coily's Avatar
Default Jaguar Voice
Have a 2007 XJR and want to install the jag voice module, dealer says no longer available. However I can get a used one for a couple hundred, can it be programmed to work in my vehicle?
Old Oct 29, 2014 | 01:58 PM
Welcome to the forum coily,
I've moved your question from General Tech Help to X350 forum. Members here with the same model will be able to help.
Old Oct 29, 2014 | 03:30 PM
anindyam's Avatar
I got mine from a fellow Jag Forums member in Australia. Check here in the classifieds and also on ebay, including ebay-uk. There's loads of posts on here on how to install, which is quite easy if you're handy.
Old Oct 30, 2014 | 09:33 AM
cjd's Avatar
cjd
Yeah...she sounds pretty hot. Anybody got her number?
Old Oct 30, 2014 | 02:18 PM
veffremov's Avatar
In most cases you don't need to re-program anything it just works. If needed the dealer can re-program the head unit to recognize it. Do you have microphone installed?
Old Oct 31, 2014 | 08:10 AM
coily's Avatar
Default supposedly just need the voice module
The dealer and our mechanic have never installed a used voice module and said there is a slight possibility that the module is specific to a VIN and may not work in a car it was not originally made for, not sure that makes any sense, but I would hate to buy the module pay for installation and if necessary dealer programming only to find out it won't work in any car other than the original one
Old Nov 3, 2014 | 01:04 PM
anindyam's Avatar
Mine was from a 2006 and I installed it on my 2004 with no issues. Can't comment on later models, however.
Old Nov 9, 2014 | 10:58 PM
shtse73's Avatar
What year/trim level did Jaguar Voice come as a standard option? I have a 2007 VDP and not sure if I have it.
Old Nov 10, 2014 | 01:30 PM
anindyam's Avatar
If you press and hold the mute button on the steering wheel, and the systems responds, then you have it. If it just mutes your radio, then you don't.
Old Jan 24, 2016 | 04:48 AM
pkoko's Avatar
Is jaguar voice worth it? Is it as good as sync?
Old Jan 26, 2016 | 03:46 PM
anindyam's Avatar
I don't have it on my current X350, but I did on my older one. I didn't use it much. Mainly used it for Nav, but I never liked the Nav unit and ended up using Google Maps on my phone anyway.
Old Jan 26, 2016 | 04:17 PM
NCJagman's Avatar
Speaking about the voice, is there any way to change the voice in the sat nav on my 2005 XJ8 VDP. I can live with it but my wife doesn't like it.
Old Jan 27, 2016 | 02:42 PM
clifton94's Avatar
Got voice on mine never seems to understand me tried training it a couple of times and I cannot remember all the commands anyway I be surprised if a lot of people use them to be honest
Old Jan 28, 2016 | 12:39 AM
bucktooth's Avatar
Best use for me is making phone calls.
JarodL
Mar 7, 2024 01:39 AM
paulyling
Mark V - X 420G
Aug 15, 2023 09:33 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
David Thompson
Sep 3, 2015 07:48 PM
