Kasuga on XJ X358 ??
Old Jun 2, 2016 | 12:00 PM
Mustang1967's Avatar
Default Kasuga on XJ X358 ??
Hi gents!
Do you know if Kasuga wheels fit on my Jag?
Thanks for infos?
all the best
Gerry
Old Jun 2, 2016 | 12:18 PM
alecescolme's Avatar
I know that you can run 4 fronts and will be 100% ok. If you want to retain the wider rears, you will need a spacer.
They are good looking wheels, but a pain to clean I bet
Old Jun 2, 2016 | 12:58 PM
thanks for quick answer:-)
Do you know which wheels are 100% fit for the x358?
all the best
Gerry
Old Jun 2, 2016 | 03:20 PM
If you get 4x 9J (front) Kasuga wheels then they will fit. The 10J rears will probably rub.
Old Jun 2, 2016 | 03:40 PM
SimonXJ's Avatar
I've got 10.5" wide ET49 (295/30 tyre) wheels on the back of mine which fit, just. Part of the inner wheel arch liner had to be trimmed away to allow the inside to fit, based on a 10" ET46 which is the spec of the kasuga they would protrude 8mm more than my wheels and have more room on the inside, based on a 275/35 tyre as per the X351, so I would suggest that the wheels would fit, and I've seen an X350 with the Matiava wheels from the X351 also which fitted as a staggered set up. I'd recommend a 285/30 tyre if you're going down the staggered route though.
But if you can get them, I'd agree with Alec and suggest 4 wheels the same size, unless you're looking for a specific look. But 20mm H&R spacers can be fitted to the rear to achieve the same effect, see JIM64's posts as he's just fitted spacers.
Old Jun 2, 2016 | 11:56 PM
Hi gents!
Thanks for your answers ! So i will check all this opportunities :- )
My problem is that my steeringwheel is still shaking, after balance (3 times) and new tires? So i don't know what can i do?
All the best!
Gerry
Old Jun 3, 2016 | 03:18 AM
clifton94's Avatar
I don't know if there are any tyre shops that do this but someone might know but they use to balance the wheel on the car
Old Jun 3, 2016 | 05:24 AM
Hi gents!
Thanks i will search for them. In Austria is a Jag XJ a really special car, so it is not easy to find the "right" mechanics.
All the best
Gerry
