Largest overall diameter tyre on an XJ without rubbing
Old Nov 1, 2015 | 08:27 AM
mrvip's Avatar
Default Largest overall diameter tyre on an XJ without rubbing
In about two weeks i'll be a new owner of a long lusted after silver super V8. I also might get a good deal on 20" Sepang wheels. I live in Bulgaria, and the road conditions here on the back roads are less than perfect. My plan is to put taller tyres on 20s, but i found a thread, stating that an overal wheel diameter larger than about 27.5" would rub the wings on some occasions, like tight turning backing up from a parking space and/or jumping off a kerb.
Any opinion on the largest overall diameter tyre I can go?
Old Nov 2, 2015 | 06:13 AM
Matei Dima's Avatar
Hi there,
I had those concerns, because I also have 20" sepangs. A member here has put 1" taller tires, and it's all ok. So that would translate 255/40 instead of 255/35.
Lucky you, that you live in Bulgaria! We're neighbours, I live in Romania, and I have to pay 2800 Euros per year just to own it, not counting fuel and repairs...
Old Nov 3, 2015 | 05:26 AM
mrvip's Avatar
Hi Matei,
Glad to have a competent Jaguar owner in proximity Are you in Bucharest? I am just 180 km away from it in the beautiful town of Veliko Tarnovo, we might drink a cofee together one day on either side of the border.
Yes, it's cheaper to run a car here, the insurance+tax would be about 1300 eur/year.
Old Nov 3, 2015 | 07:58 PM
Matei Dima's Avatar
That's a lovely idea, however I'm at the other end of the country, near the Hungarian border. But I'll be sure to let you know when I have business in the Sout-East, by then you will have gotten your Jag There are 2 types of Super V8s, long and short wheelbase, which are you planning to buy?
Old Nov 4, 2015 | 11:20 AM
mrvip's Avatar
I prefer LWB for the long low look, but I can't seem to find any at a reasonable price, so i had to settle for SWB. I'd be really glad if you drop me a message when you are around, a nice little trip on the new wheels should be refreshing
Old Jan 25, 2016 | 10:18 AM
lukie's Avatar
I am in the UK, I have a XJ8 X 350 with 225/40/19 and they tend to rub on a wheel lock
Old Jan 26, 2016 | 02:30 AM
doc's Avatar
doc
I have 245 40 19 front and 275 35 19 rear on my XJ8 seems fine
Old Jan 26, 2016 | 05:34 AM
mrvip's Avatar
I tried the 255/40R20 front, 285/35R20 combo. It seemed perfectly fine for about a month, until the car is with one front wheel a lot higher up than the others, like on a kerb, then the opposite rear side squats a lot and the rear wheel is rubbing the lip of the plastic wheel liner. Eventually it cut through it and i had to replace the liner. It turned out there was a bit of rubbing on the inside as well. Then i switched to 255/40R20 at the back and have no problems whatsoever for two months. I tried the tilted position and there is enough clearance with the 255's, even room for 265. 275 might work too.
Regarding my initial question, diameter is a non-issue, but my car sits a bit high, plan to lower it a bit.
Old Jan 26, 2016 | 05:38 AM
mrvip's Avatar
It's really strange you get rubbing, your tire diameter is smaller and widths is narrower than stock combinations.
Sean W
Dec 14, 2015 01:24 AM
SEBZX79
17
Nov 4, 2015 07:41 AM
Cambo
XF (X260)
Oct 31, 2015 04:41 PM
philwarner
Oct 31, 2015 03:42 PM
alanfjones1411
Oct 27, 2015 02:18 AM
