Led low beams
Old Jan 10, 2023 | 12:04 PM
Eric-in-Texas's Avatar
Default Led low beams
Has anyone done this successfully? What source? Will the Amazon ~$40 set work, or is something more elaborate needed to avoid Can buss errors? BTW I searched this first & it failed to provide any useful posts.
Old Jan 10, 2023 | 05:31 PM
ctsemicon's Avatar
Extremely pleased with these...
Amazon Amazon
AUXITO H7 LED Light Bulbs 6500K White
Old Jan 10, 2023 | 05:46 PM
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Ordered Thanks.
Old Sep 14, 2023 | 01:13 PM
G.M. Webster's Avatar
So did the Auxito work without any error messages on the dash? Any issues with longevity? Do they appear any brighter than factory? Mine are so low and dim it is hard to drive at night.
Old Sep 14, 2023 | 02:02 PM
ctsemicon's Avatar
Default LED Low Beams
Still very pleased with mine after 6 months. It does (to my old eyeballs) improve low beam lighting significantly.
One note - I would avoid the fan-cooled version of LED bulbs. 1) I cannot see how a fan is really going to help in a sealed container like the XJ8 lamp housings, its just going to recirculate the heat, and 2) if they need a fan, it means they could be pushing current beyond what the LED OEM (Cree, Nichia, TCPI) might recommend in order to advert high lumens.
If I am out at night, I will post a pic, but its too late for a before .
Old Sep 26, 2023 | 04:53 PM
FWIW, I bought these for $29 on Amazon and installed them yesterday. It took me about an hour because it was sort of tricky to put the bulb in. On my car, at least they are a little longer than the stock H7 bulb and so they rub against the "deflector" making it difficult to seat correctly. Eventually, I installed them, and they are definitely better than the stock low beam bulb. My complaint is that, while they are brighter and have the cooler / bluer light, the light pattern is a little more diffuse than I would like. We'll see if they last, but I hope they do.
Johnken
Jan 22, 2022 02:02 AM
wymjym
Oct 13, 2019 02:48 PM
280zx-turbo
Oct 6, 2018 09:25 PM
Clackavosticus
Aug 1, 2018 02:01 AM
