Locked in.
Old May 15, 2012 | 02:24 AM
BOB7747's Avatar
Default Locked in.
Unlock car, get in start motor, then I can't unlock the door, I have to stop Engine, take key out then press unlock on the key fob. Any ideas. Car is a 2004 XJR.
Old May 15, 2012 | 05:07 AM
Fraser Mitchell's Avatar
I assume you have the 'door locking on driveaway' operating, which only operates when you put car into gear from Park. Once locked, I think you have to first pull the unlock lever, then the door unlatch lever below.
I may be wrong, though. It's not clear in JTIS. What does your Owner Handbook say ?
Old May 15, 2012 | 05:55 PM
jahummer's Avatar
Do you have a central lock/unlock button on the center of the dash console? You should also just be able to pull the inside door handle which manually unlocks the door and automatically unlocks all others.
Old May 15, 2012 | 09:09 PM
meirion1's Avatar
Default locked in
This has happened to me a couple of times-did you try the passenger door handle?
Old May 16, 2012 | 02:45 AM
BOB7747's Avatar
It has been fine for the last few times, will check on your suggestions when it happens again.Thanks.
jluckcuck
Nov 6, 2015 07:49 AM
Delta66
Oct 4, 2015 05:40 PM
millertic
Sep 30, 2015 08:11 PM
Bigvettefreak
Sep 28, 2015 03:03 AM
