Lowered My XJR For 48 Cents
Old 08-23-2016, 11:41 AM
viper1996's Avatar
Default Lowered My XJR For 48 Cents
The gap on the rear I found is fine to me, but when the car suspension is in driving mode the front appeared to high. I installed 2 pairs of washers per side under each ride sensor mount where the 2 bolts go through, which will lower the car 13mm. It is amazing how much the small difference makes in the stance of the car! In rest mode it still sits nice as well...It doesn't look to low after sitting...8 Hillman washers @ 6 cents each to make your car look better...Such a deal!
Old 08-23-2016, 11:44 AM
viper1996's Avatar
Old 08-23-2016, 11:45 AM
viper1996's Avatar
Drive mode Name:  20160823_105440_zpslthuyndc.jpg
Old 08-23-2016, 11:50 AM
viper1996's Avatar
Rest mode Name:  20160823_095516_zpsv88uinno.jpg
Old 08-23-2016, 11:56 AM
viper1996's Avatar
You can go lower if you wish...I just wanted to close the front gap down modestly...Each washer equals 1/4 or 6.5mm of drop. So 2 washers under each bolt equal 1/2 inch or 13mm of drop. 3 washers equal 3/4 or 19.5mm of drop, and so on..3 washers made it look to low in rest mode to me.The same goes for the rear if you want that lower too...Do not over tighten the sensor mounting bolts or they will strip and you be using self tapping bolts instead!!! No noticeable difference in ride that I could tell!
rosskuhns (09-02-2016)
Lawrence
XJ40 ( XJ81 )
04-03-2016 07:20 AM
powerhouse
04-02-2016 02:55 PM
DanielSWE
03-28-2016 06:22 AM
psb1013
03-27-2016 07:28 PM
IronCobra
02-11-2007 12:01 AM
Quick Reply: Lowered My XJR For 48 Cents
