maximum coolant system pressure ?
Old Jun 11, 2020 | 06:26 AM
nebelfuerst's Avatar
Default maximum coolant system pressure ?
My jag looses small amounts of coolant. ( 50ml / 100km, when driving at full speed )
I changed coolant reservoir, an O-Ring at the reservoir, the cap of the reservoir with no success.
So I bought a pressure tester, but I wonder how much pressure can be applied to the system ?
( I want to fix it, not blow up my coolant system ;-)
Old Jun 11, 2020 | 07:38 AM
mhamilton's Avatar
15 psi is generally the maximum. The reservoir cap should have the stated max pressure.
Old Jun 11, 2020 | 12:26 PM
Is this also the limit for pressuring to find a leak ?
I read of dealers for other brands, which apply much more than the nominal pressure to find leaks.
But for this I need some limit not to damage something..
Old Jun 12, 2020 | 07:18 AM
mhamilton's Avatar
Yes. You do not want to over pressurize the system to find a leak. You'll just create a new one--blow out a heater core, gasket, etc.
Brian H Smith
Apr 21, 2020 08:47 PM
Johnken
Dec 30, 2019 04:44 PM
bocatrip
Jun 27, 2019 09:25 PM
zerochills
May 16, 2019 11:12 PM
Jack Kass
May 14, 2017 11:35 AM
