Mina pulley to do or not?
Old Feb 17, 2013 | 06:22 AM
Robert Page's Avatar
Default Mina pulley to do or not?
Well guys I need some advice I am going to order the Mina intake and as they are offering a package with the SC pulley I was thinking I might as well get both. Now has anybody fitted one to the X350? If so once you have cut the old pulley off is fitting simple? I am worried my Indy guy may have trouble squaring the new pulley up for the belts to drive properly. Also any thoughts on the belt should I change to the Goodyear gator belt or stick with a later model OE belt. Any advice would be appreciated.
Old Feb 17, 2013 | 07:03 AM
rocklandjag's Avatar
I installed a pulley from Powerhouse and the front of the pulley aligned with the end of the S/C shaft. To install this one you have to super heat the pulley and install quickly before it cools and locks onto the shaft. I used the smaller pulley so I had to machine the snout to allow the pulley to fit around it
Old Feb 18, 2013 | 05:54 AM
912guy's Avatar
I would go with the pulley from euro-imports with the install pulley and a low temp thermostat..300.00-350.00 The pulley is for rent for 150.00 to install.These guys are from Chicago...
xjrjag
Oct 12, 2015 03:16 PM
inactualis
Oct 2, 2015 11:13 AM
XJ8JR
Oct 2, 2015 12:13 AM
dan102877
Sep 29, 2015 06:47 PM
