nav system
Old Jan 18, 2009 | 11:47 AM
newbiexj8's Avatar
Default nav system
Question:
I have a 2006 xj8l -the nav system does not allow you to operate it while driving - although I understand Jaguar's reasoning for this(safety). I personally would never try and use the nav system
while driving - is there anyway to bypass this "lock-out"?? Again ,although safety is Jaguar's goal here, what doesn't make sense about it is this: often one might be are driving in an unfamiliar areaand might need to figure out how to get somewhere or need to find a alternative route or need a hotel listing or whatever........... -this system does not allow the passenger to use the nav system while the car is moving - I also have a mercedes w/nav and it does allow use of the nav while driving -I can't tell you how many times my wife has used the nav system as a passenger - any thoughts ideas??
Old Jan 18, 2009 | 02:03 PM
xdave's Avatar
Default RE: nav system
Upgrade to the latest software version by purchasing a 2007 or later map and software DVD. The ability to use the navigation features whilst in motion was enabled from that version onwards.
Old Jan 18, 2009 | 03:00 PM
Real_Tech's Avatar
Which software level do you have now? Is your start up screen a green background with a 3D leaper or is it a black background with a white outline leaper?
Old Jan 18, 2009 | 08:27 PM
jahummer's Avatar
ORIGINAL: Real_Tech
I have the 2009 DVD which did a software update upon upon initial load and changed the logo screen as you described. I noticed some minor changes to the nav system but what specifically has changed with use while driving as I do not see anything different there.
Old Jan 19, 2009 | 10:53 AM
newbiexj8's Avatar
I need to double-check, but I believe it's black w/white - ????
captbob73
Oct 24, 2015 05:49 PM
jdzubas
Oct 4, 2015 09:14 AM
Jagfastic
Sep 14, 2015 07:41 PM
texaspete
Sep 10, 2015 08:34 AM
Mike Green
Sep 7, 2015 12:39 AM
