Navigation orientation problem
Hi folks,
Car went to dealer and had some flashing done on ECU and trans. When I am in the car sometimes my navigation indicates the car is traveling towards me on the map images versus traveling forwards. I have played with the settings to no avail. Is this how the navigation usually works or is there an orientation problem with the GPS sensor? I went in to the menu setup using the pin code and tried to re-orient the car, but no luck.
Thanks for any tips.
Keith
Keith
You have the option to keep the screen always pointing north or towards the direction you are traveling. That can be changed by ckicking the compass icon in the upper left corner of the screen. I hope this is what you are talking about.
