navtool problem!
Old Sep 7, 2012 | 04:19 AM
erikhuldt's Avatar
Default navtool problem!
Hello!
Im having some problem with installing a navtool unit to my 2008 jaguar xj.
The problem is that i don't know what the different wires are doing.
i cant follow the navtool manual because the color that they say i should doesn't match the nav unit in the xj.
if you look att the picture, is there some one who have an idea how i should connect the wires from the navtool unit?
http://forumbilder.se/show.aspx?iid=dd201244316PMdd32
best regards
Erik
Old Sep 8, 2012 | 12:26 AM
jag4life's Avatar
Hi I'm with NavTool support
Wires you need to interface are
In 26 pin connector
Pin 1 sync signal
Pin 2 green signal
Pin 14 red signal
Pin 15 blue signal
Pin 16 video ground
Red*********************** =*** From NavTool connect red wire to screen side and yellow wire to navigation side
Green****************** = ***From NavTool connect blue wire to screen side and green wire to navigation side
Blue********************** =** From NavTool connect purple wire to screen side and orange wire to navigation
Sync********************** =* From NavTool connect *black wire to screen side and brown wire to navigation
Old Sep 8, 2012 | 06:43 AM
erikhuldt's Avatar
Big thanks! now it working!
regards
Erik
Old Sep 8, 2012 | 01:44 PM
erikhuldt's Avatar
now i have an other problem!
i have installed the acm but it doesn't work all the time. 50 % of the times it just shows disc 6 and i can not use my usb stick. have tried 2 different sticks and have just got my 4 gb kingstone stick to work but not all the time, have to turn on and of the car sometimes for the acm to recognize the usb stick..weird
someone who has an idea?
Old Sep 9, 2012 | 03:21 PM
erikhuldt's Avatar
installed densions latest firmware and now its working
Old Sep 9, 2012 | 05:59 PM
H20boy's Avatar
Well, that was going to be my only suggestion erik.. Enjoy!
Old Sep 10, 2012 | 02:05 AM
erikhuldt's Avatar
Clamdigger
Sep 12, 2015 03:43 PM
dragonfly777
Regional
Sep 8, 2015 01:39 PM
mcdutch
Sep 4, 2015 03:38 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
