new 2004 xjr
gentlemen
i took the car to the mechanic knowing i have and issue either in park or neutral or driving i have a rumble or vabration aroung 1800 rpm less fetl at higher speeds i was told it could be either flex plate or torque converter ,am dying to resolve the issue just dont wonna trow money away any help would be greatfull
thank you
thank you
that is correct it does it in all I do notice the vibration is felt more in the first 2 gears as your speed increases is felt less at 70 milesnyou don't fill much less if you step on it
thanks
thanks
It sounds as if your mechanic could be right and if so
then it would be quite an unusual fault on these cars.
Not the same jag but more possibilities here:
https://www.justanswer.com/jaguar/4d...ing-wheel.html
Others on this forum may have experience of this fault and may reply.
more info here:
https://www.google.com.au/search?q=j...hrome&ie=UTF-8
more info here:
Lagonia
Nov 19, 2013 02:09 PM
