new owner needs help - hi-beam and rear sidelight
Old Jul 17, 2013 | 09:35 PM
imajag61's Avatar
Default new owner needs help - hi-beam and rear sidelight
just bought my first jag, 2005 XJR.....driver side hi-beam is out ,replaced the bulb and still not working ?????
same for the right rear side light (part of bumper) little rust in the socket cleaned it out and put a little Vaseline in it ...no luck
any ideas on why this is
Last edited by GGG; Jul 18, 2013 at 02:37 AM. Reason: edit thread title to add detail
Old Jul 18, 2013 | 02:34 AM
Welcome to the forum imajag61,
I've moved your question from General Tech Help section to X350 section. Members with the same model will be able to help with the lighting issue.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Jul 18, 2013 | 10:13 AM
To help others give relevant advice, you should add:
1. halogen or HID headlamps fitted
2. fuses checked
If you don't have the Driver's Handbook with the fuse locations, post back here and I'll put the list up.
Old Jul 19, 2013 | 02:29 AM
imajag61's Avatar
halogen or hid ? sorry how do I tell ? I looked in manual and it refers to the main lights as the inner set and the dipped beams as the outer ? dipped = hibeams?
are there 2 fuses for the inner set mains ? I will check fuses
Old Jul 19, 2013 | 04:00 AM
The main beam lamp unit and the front parking (side) lamp are in the inner unit and the dipped beam and the turn signal lamp unit are in the outer. Dipped are fused separately but both main beams are on the same fuse:
Standard Halogen (H7) bulb headlamps simply have a bulb holder:
The HID headlamps consist of a headlamp bulb and a combined ballast and headlamp leveling module fitted to the headlamp. Burner wear for HID lamps is so low that the burner lasts the lifetime of the vehicle under normal use. Headlamp automatic leveling is controlled by the air suspension module receiving information from the controlled area network (CAN) data.
The HID setup has a lot more to go wrong!
Old Jul 19, 2013 | 07:27 AM
rhankey's Avatar
Your terminology sounds like you are in North America. Dipped=low beam (outer lights); Main=high beams (inner lights). The lights vary a bit by geography or options, especially the dipped/low beam, which is why you are getting questions as to the type of bulbs you have. However, I should think the main/high beam bulbs are halogen bulbs in all markets.
Old Jul 19, 2013 | 12:39 PM
imajag61's Avatar
ok all halogen, also my hi beams are the inner set of lights and mains are the outer,opposite of what the manual says.Yes Im in the USA. Are there seperate fuses for the hi beams(inner set).
99xk8guy
Sep 29, 2025 10:51 PM
Forcedair1
Sep 8, 2025 01:57 PM
EZDriver
Sep 8, 2015 09:25 AM
RaceDiagnostics
Sep 7, 2015 07:28 AM
Tar
Sep 6, 2015 11:24 AM
