O/S/R Indicator issue
Old Sep 25, 2019 | 07:14 AM
BDuncan's Avatar
Default O/S/R Indicator issue
Can anyone help. When I put on my indicator on O/S and N/S they work fine. But as soon as I put on my side lights or headlight when I put on the N/S Indicator it flashes dimly and the O/S Side light and indicator flash as well. Any suggestions.
NB:- When I put on my hazard lights without the side lights on it works fine all round.
Old Sep 25, 2019 | 07:36 AM
JX350's Avatar
Hi Bruce,
A grounding/earth issue possibly?
Thanks,
Chris
Old Sep 25, 2019 | 09:41 AM
BDuncan's Avatar
Thanks Chris
Old Oct 1, 2019 | 10:18 AM
BDuncan's Avatar
Still having issues and noticed that when I put on my N/S/R indicator my brake and O/S/R indicator also come on but very faint.
Old Oct 2, 2019 | 01:54 PM
wwr's Avatar
wwr
Bruce;
+1 on the grounding.
Using the Electrical Guide, identify, locate, and check out the FEM and head/fog lamp chassis ground connections.
Multiple forum members have had issues with these chassis grounding connections.
If these chassis grounds all look good, verify continuity from the FEM and head/fog lamps back to ground.
Best Regards, William
Old Oct 3, 2019 | 06:02 AM
JX350's Avatar
I had many strange electrical issues which were fixed by replacing the ground points behind the headlights, which is why I suggested a ground issue somewhere.
Thanks,
Chris
Old Oct 4, 2019 | 02:38 AM
BDuncan's Avatar
Tried the FEM and ended up putting into Auto Electricians. Fault diagnosed as REM (Rear Electronic Module)
BDuncan's Avatar
WWR,
ended up putting into Auto Electricians. Fault diagnosed as REM (Rear Electronic Module) Thanks for your assistance.
Old Oct 4, 2019 | 02:29 PM
wwr's Avatar
wwr
Bruce; Did you actually replace the REM and it corrected the problems?
Old Oct 7, 2019 | 05:43 AM
BDuncan's Avatar
Wwr
Problem resolved by fitting new REM (Rear Electronic Module)
Old Oct 7, 2019 | 02:12 PM
JX350's Avatar
Great to hear Bruce. Glad you got it fixed and thanks for letting us know what the solution was.
jonijoni
Oct 10, 2019 09:58 AM
savhomer
22
Jun 6, 2013 06:11 PM
1994jigglywirexj6
XJ40 ( XJ81 )
Dec 10, 2012 04:24 PM
Navionsam
May 14, 2012 10:51 AM
Jun 20, 2007 03:28 PM
