O/S/R Indicator issue
Can anyone help. When I put on my indicator on O/S and N/S they work fine. But as soon as I put on my side lights or headlight when I put on the N/S Indicator it flashes dimly and the O/S Side light and indicator flash as well. Any suggestions.
NB:- When I put on my hazard lights without the side lights on it works fine all round.
Bruce;
+1 on the grounding.
Using the Electrical Guide, identify, locate, and check out the FEM and head/fog lamp chassis ground connections.
Multiple forum members have had issues with these chassis grounding connections.
If these chassis grounds all look good, verify continuity from the FEM and head/fog lamps back to ground.
Best Regards, William
Tried the FEM and ended up putting into Auto Electricians. Fault diagnosed as REM (Rear Electronic Module)
savhomer
22
Jun 6, 2013 06:11 PM
