oil in the trunk/boot.
Old Jun 28, 2014 | 06:49 AM
electraglide1600's Avatar
Default oil in the trunk/boot.
Hi, I have a bit of a quandry to deal with. I moved my car today ('05 4.2 xj lwb) and noticed a rainbow on the wet drive. on further inspection the oil which caused the rainbow was leaking out of the left hand side boot/trunk drain tube. After removing everything from the boot I could see oil pooling in the channel directly under the air suspension tank. My question is could this oil have come from said tank or is there anything else in the boot which may leak? there are no fault codes on the display. Any help appreciated. Rod.
Old Jun 28, 2014 | 07:14 AM
Fraser Mitchell's Avatar
Are you sure there isn't a little bottle of oil down there that is leaking ? Jaguar dealers normally give out a 1/2 litre bottle of oil plus a pair of rubber gloves and a folding paper funnel at each oil service. It's contained in a small bag. Mine has Castrol Professional on the outside.
There is no oil used in the air suspension, and there are no oil lines there either. If the oil was coming from the air reservoir tank, it would not be holding air pressure, and you'd have a fault message.
Old Jun 29, 2014 | 03:58 AM
PigletJohn's Avatar
what colour is this oil, when you wipe it up with a clean white tissue?
Old Jun 29, 2014 | 04:04 AM
Smile
Hi, there was a bottle of oil in there with a pin ***** hole in the bottom corner, phew, that wasn't as expensive as i thought it would be...thanks for taking the time to reply chaps. all the best, Rod.
Old Jun 30, 2014 | 05:40 PM
Clearly the previous owner liked to hide away his valuable spare oil !!
MrWhite
19
Jun 14, 2022 07:49 PM
Dave1109971
Dec 15, 2015 06:16 PM
3jagfamily
Oct 1, 2015 01:49 AM
Woznaldo
Sep 26, 2015 11:02 AM
ahunt4
Sep 25, 2015 03:43 AM
