p0560 code (low voltage) - 2006 Jaguar XJR
Old Oct 31, 2020 | 09:23 PM
XJR_NY's Avatar
Default p0560 code (low voltage) - 2006 Jaguar XJR
Hi everyone,
I'm getting check engine light (p0560; low voltage) stored, and pending. ECM will perform readiness test on misfire, fuel system and comprehensive component, as well as 0xygen sensor heater (HTR) and Exhaust gas recirculation (EGR) - leaving Evaporative system (EVA) and 0xygen sensor (02s) 'not ready'. At this stage P0560 (low voltage) is displayed and resets the readiness testing for 3 out of five. As such the vehicle is not able to pass state inspection (NY).
- Mechanically, everything else is in order. mpg is normal, idles well, no misfires. However upon every startup, monitor readiness tests are reset whereby 5 of 5 non-continuous measures shows incomplete.
Pic below (pardon the size) shows the closes i've made it to the mandatory 4 of 5 system ready tests. The ones I am able to clear (EGR; CAT; HTR) all respond reliably to the posted drive cycle.
The remaining two however (O2S; EVA) does not come on. According to the drive cycle, EVA requires a 30 second ignition of sequence, which then resets all previously cleared codes.
Check engine light (p0560) shows up intermittently.
Please advise!
Old Nov 1, 2020 | 06:33 AM
brian5's Avatar
First thing I'd get checked is the battery, battery related faults are very common on these cars, Get it properly tested, it may seem fine, but even being down a couple of volts can cause mayhem, been there, done that, replaced the battery and it was a different car. Also check earth connections, they too can cause problems, because the chassis is Aluminium and the earth studs steel, they can come loose, I believe a common culprit are the studs behind the headlights?, after that you might want to check the charging system, could be a weak alternator.
Hope this helps
Johnny_B
Jun 17, 2020 02:09 AM
Dicque
Jan 28, 2016 11:33 AM
MTZGR777
Feb 7, 2010 07:22 PM
keithinatorx
Jul 3, 2009 06:07 AM
