P1647 fault
Old Sep 27, 2017 | 11:05 PM
roydrick titus's Avatar
Default P1647 fault
I changed the o2 sensor before the catalytic converter on the passenger side. Reset the code, removed power to the battery for 30 minutes, and after starting the engine light was gone. Drove 3 miles parked, and no light. After starting the second time the engine light came back on and has not went away. I've only driven 80 maybe in hopes that the light would go off. Any ideas?
Old Sep 27, 2017 | 11:09 PM
I forgot to mention 2005 XJ8L
Old Sep 28, 2017 | 01:27 AM
JagV8's Avatar
Apparently not fixed. As the manuals say it's a 2-trip code.
Hopefully your location (wherever it is) means you changed the right one and hopefully you used the correct kind.
If so, check wiring etc.
Old Sep 28, 2017 | 06:55 AM
brian5's Avatar
Are you sure you changed the correct sensor? There are 4 in total, 2 before and 2 after the cat on each bank, That code relates to the Left hand bank, as you sit in the car, front sensor on the manifold side of the cat. Also as yours is an 05, its right on the change, the sensor part numbers changed between 05 the and 06 update, probably wouldn't make a difference but you never know.
Old Sep 28, 2017 | 11:45 AM
What does it mean by two trip code?
Old Sep 28, 2017 | 11:49 AM
I thought that I read upstream bank 2 was on the passenger side before the cat. So it's actually on the drivers side?
Old Sep 28, 2017 | 12:57 PM
JagV8's Avatar
Depends where you live... LHD/RHD are always as named but passenger/driver... depends.
Old Sep 28, 2017 | 01:02 PM
Ok I live in the U.S. So that makes my bank 2 on the passenger side or the drivers side?
Old Sep 28, 2017 | 02:14 PM
HuskerJag's Avatar
I have the same P1647 code, and researching the topic. From what I've read this is Bank 2 which aligns with the even number cylinders of the V8 engine. Those cylinders are on the Driver side.
I have a thread in this forum trying to verify if I'm correct too.
Standing by
Old Sep 28, 2017 | 02:37 PM
HuskerJag's Avatar
I just reviewed a X350 Jag manual, for 2005 4.2L with VIN Range of G00442->G45703, and it states the P1647 as: "Left-hand ECM HO2S
control malfunction". I made a copy of the diagram with title and location of the sensors. I'm going to try and attach it.
Old Sep 29, 2017 | 03:26 AM
JagV8's Avatar
Sounds like changed sensor on wrong bank.
Old Sep 29, 2017 | 05:08 AM
brian5's Avatar
To Clarify, no matter what country you are in, Sitting IN the car facing forward, Bank 1 is on your left, Bank 2 is on the right.
Old Sep 29, 2017 | 03:12 PM
JagV8's Avatar
Other way around.
(Bank 1 is the one with cyl 1.)
https://www.jaguarforums.com/forum/a...8fireorder.jpg
Old Sep 30, 2017 | 06:00 AM
brian5's Avatar
My Bad, see how easy it is to get it wrong?, LOL
Yes, so to really clarify, Sitting IN the car, Bank 1 is on RIGHT, Bank 2 is on LEFT.
