Parralelism geometry recommended
Old Mar 11, 2010 | 01:00 PM
xjpassion's Avatar
Banned
Default Parralelism geometry recommended
Hello,
What do you recommend for the geometry?
I am changing tires now ,for some Dunlop Sport Max,first time ,i quit buying Pirelli.
thank you
Old Mar 11, 2010 | 01:02 PM
xjpassion's Avatar
Banned
Most of the time ,I am on the freeway and in low position.
Old Mar 11, 2010 | 03:34 PM
avos's Avatar
First of all, Arden should be able to advise here, they have provided you a kit and I would assume they should be able to recommend.
2" lower is a lot imho, and you would require a special setup for this. If not your tires are going to be eaten on the inside pretty quick. I am not a specialist in this area, but you will need one to get a special setting for the height you prefer. It will also take some work to get the camber right on the rear as you need to replace shims on the drive axle.
My advice would be to choose the ride height as you like and then set the suspension geometry right for that.
Old Mar 11, 2010 | 06:01 PM
xjpassion's Avatar
Banned
thanks Avos,
yes it is well 2 inches ,4,5 cm indeed.
Old Mar 14, 2010 | 11:24 AM
xjpassion's Avatar
Banned
there is nothing I need to replace,
what is the maximum negative camber ("carrosage") you can go? on the x 358
Old Mar 14, 2010 | 11:34 AM
avos's Avatar
Assumed you had a 308 as then you need to replce shims at the rear, don't know it for the 358.
Old Mar 15, 2010 | 02:40 AM
xjpassion's Avatar
Banned
yes it is a 358 going up to -1,25 negative camber may help.
Msteiner
May 16, 2016 12:19 AM
jagtoes
Apr 22, 2016 07:37 AM
MrWhite
33
Oct 22, 2015 10:29 AM
mrplow58
Sep 30, 2015 08:56 AM
ChrisJay
Sep 27, 2015 09:08 AM
