Paul
Old Mar 23, 2020 | 07:59 PM
Paul Griffis's Avatar
Question Paul
Initial morning start, idle is too high.. last 5 seconds
How to idle down only that phase of morning start
Old Mar 23, 2020 | 08:50 PM
Wingrider's Avatar
They do run a little fast on start up, then slow down after about twenty seconds or so.
Old Mar 24, 2020 | 05:47 AM
EsRay's Avatar
Agree with Wingrider;
Mine stats at around 1200 revs, then drop over the next 10 - 15 seconds; that is when I engage Drive. I also get a "Death Rattle" for about 3-4 seconds; I understand that it is caused by loss of oil pressure in my VVT units as they attempting to peg the Cams (although I could be wrong about that)?
Old Mar 24, 2020 | 01:49 PM
Panelhead's Avatar
Default You might try another brand of oil.
When I first got mine it had fresh Mobil 1. Switched to Castrol Euro blend 0-w40 after a 1000 miles. This took a while, car had suspension rubber rot. Spent way more time on jacks than road at first.
Switching to Castrol made start up quieter. Less banging and clanging.
After a couple changes switched to Rotella. Seems a little quieter still. No noises in the morning.
Have not tried M1 again to see if noises return on startup.
Old Mar 24, 2020 | 08:00 PM
Question
Has recently had new gaskets replaced on the entire top of the motor and under the supercharger, new plugs, and when I got it back from this work being done to it my initial starting idol was Higher ..on the initial start I don't want it to idle that high it appears to me it will eventually throw a rod
Old Mar 24, 2020 | 09:47 PM
Panelhead's Avatar
What is the rpm it revs up to on startup? A vacuum leak will speed up, but should not get better after 5 seconds. ECM should prevent this. Maybe it does, just takes 5 seconds.
Old Mar 25, 2020 | 01:20 PM
Blairware's Avatar
You can supposedly re-calibrate the throttle motor/signal on the throttle body with a battery disconnect/reconnect. There is a reostat in the throttle pedal that signals a motor on the throttle body. Torque Pro (OBD2 App) sued to show my throttle at 20% with the pedal untouched. Upon reconnecting you do a throttle range input,then let it idle for a few mins to calibrate the drive-by-wire accelerator. After doing this several time my throttle was calibrated, but it never stayed that way, so it may not be worth the effort.
Here is a thread that discusses the re-connect procedure and throttle travel calibration as well as IDLE CALIBRATION - Its for XK models, but includes the 4.2 Liter. Easy thing to try and could put the idle right for you:
https://www.jaguarforums.com/forum/x...ect-faq-74146/
https://www.jaguarforums.com/forum/a...connection-pdf
Ben_NZ
Mar 21, 2021 02:18 AM
Spikepaga
Jul 19, 2017 03:53 PM
Bocajag
E type ( XK-E )
Feb 20, 2016 08:47 PM
pwrful4
Mar 12, 2011 04:23 AM
