Performance Camhafts
Old Oct 30, 2014 | 01:01 PM
Robert XJR's Avatar
Default Performance Camhafts
Why can't I find performance camshafts for my 05 XJR? Do they exist? Where can I get them? Any help would be appreciated. I may have to remove mine to replace the lifters/buckets (whatever they're called) and I don't like reusing stock parts if I can avoid it. If it needs removed, it needs replaced with something faster. I'm doing the supercharger now too. It would be a wicked good time to do them all together (cams and SC upgrade).
Old Oct 30, 2014 | 08:16 PM
doc's Avatar
doc
I can tell you from my experience with my XJR6
I also tried to get camshafts I did track down a company in the UK that make new billets for the AJ16 engines but no one was able to grind them to specs that suited my car so I gave up
Don't get re-machined ones where they regrind the old blanks they don't work tried that with my Mercedes 450SL V8 I had many years ago
couple of the cam lobes wore off and pretty quickly I might add
Old Oct 30, 2014 | 08:20 PM
Cambo's Avatar
Avos had the cams in his 4.2 reground by a Belgian camshaft specialist, that's the engine that did 630HP...you'd have to ask him for more details though...
Delta66
Oct 4, 2015 05:40 PM
Johncy2000
Oct 2, 2015 01:05 AM
1100me
Oct 1, 2015 11:49 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
