Please help transmission
Old Apr 20, 2014 | 04:10 PM
roviw's Avatar
I had my reflash done on the X350 about 5 years ago and it was around £90 or so at my main dealer
Old Apr 20, 2014 | 04:40 PM
Lagonia's Avatar
I went to an independent Jag outfit here in Austin and he charged me 1 hr of labor which cost me $100. I now have my own IDS/SDD software setup and can do it on a whim
Old Apr 20, 2014 | 07:03 PM
Frank M's Avatar
Can I ask where you were able to get the software? Also the flash?
thanks
Old Apr 20, 2014 | 09:02 PM
alanroberts50's Avatar
I think the main thing is not to panic, because your symptoms indicate that a reflash of software in the TCM is all that is needed.
I have now had two software reflashes, one in summer to cure rough changes in the lower gears, especially 2-3, and only the other week to (at last) cure the "hunting syndrome" which occurs during warm-up. This latter I had noticed shortly after buying the car, but had put up with it until recently, but decided to finally get it fixed. These software reflashes are not expensive.
The transmission fault light coming on can also cause the car to go into "Limp Home" mode and lock the car in a particular gear, but can usually be cancelled by switching off the engine, but the fault will continue until the reflash has been done. These reflashes arise from service experience with the ZF gearboxes, plus customer complaints. If it occurs during warranty then the customer pays nothing, but after that the labour is charged, although the revised software is free.
Hope this helps you.
I sometimes get the bump between one and two but it's quite intermittent sometimes with several days in between. (feels like it needs to be let of its leash!) It's an 04 xj8 with 53k mls. not sure if it needs a reflash or fluid change? What will be the next symptom to show up?
Also there was a recent thread i think (which I cant seem to locate) entitled something like "dangers asscociated with reflashing the transmission" Anyone recall what that was about?
Alan
Poet
Feb 7, 2025 02:18 PM
Marka
22
Sep 11, 2016 12:09 AM
dmatthewman
Sep 30, 2015 10:10 AM
Old_Doc
Sep 29, 2015 03:43 PM
