posi-trac ?
Old Jan 6, 2022 | 11:33 AM
MaxTorq's Avatar
Default posi-trac ?
is there one to be had for these x350/358's ?
max
Old Jan 6, 2022 | 01:50 PM
JagV8's Avatar
LSD? There are threads to read.
Costly.
Old Jan 7, 2022 | 05:45 PM
luv2fly's Avatar
Quaife in the UK. Paramount Performance in the UK. Others there.
Old Jan 7, 2022 | 10:00 PM
Eric-in-Texas's Avatar
There is so much Ford in these cars (or Jag in the Fords), I wonder if the differential from a T-bird or LS might not fit. If that did work, it would be larger, and cheaper. Even on the XJR, the Diff looks to be about a 7", the T-bird Super Coupe had an 8.8, and likely quite a few were posi.
Old Jan 7, 2022 | 11:10 PM
scooterforever's Avatar
There are various threads on this site on swapping in an 8.0 LSD from the likes of a '02 Lincoln (off the top of my head). It isn't plug and play but folks have done it on the cheap that way.
I have a thread going on my Quaife install. The differential is assembled and now I just have to find time to pull the stock one out and swap in the LSD. I'll probably replace the rear control arms while I'm at it as I chase down some squeaks in the suspension.
Tigre
Sep 22, 2021 12:54 PM
dalo
Dec 15, 2020 01:08 PM
dwdooley
Oct 25, 2018 09:52 AM
