Quest For 450 Horsepower
Old Oct 28, 2016 | 12:29 PM
  #201
viper1996's Avatar
Were the mini cats the 200 cell cats you bought? Or did you bypass the rear cats?
Old Oct 28, 2016 | 01:07 PM
  #202
jackra_1's Avatar
"Mini cats" are extension tubes containing cat cells that are inserted into the rear O2 sensor hole with the actual O2 sensor screwing into this extension to avoid any MIL error.
So I installed the Paramount 200 cel sport catalytic converters and then the mini cats.
Thats when the discussion went into the facts about the minicats causing extra
rich fueling at high throttle openings.
I definitely do not want that so I took out the mini cats and will live with MIL warning light if and when It comes up. I will clear it tho when it happens.
To get thru emissions I will re-install them. No big deal.
Plus if and when the ECM tune that Cambo is working on comes out AND IF I can install it I should be very good indeed.
Old Oct 28, 2016 | 03:17 PM
  #203
caldoofy's Avatar
"Or did you bypass the rear cats?"
There are no rear cats in these cars, 2 in total ( one for each bank of the v ).
Old Oct 28, 2016 | 03:47 PM
  #204
Datsports's Avatar
I am leaving my stock cats on after reading all of this!
Trust me - get rid of those horrible things , they are restrictive when new and when thay start to fail they are like a brick wall biult into the exhaust system .
Not at all what a performance engine needs .
I haven't seen a MIL at all yet in 3-4000km with 200cell cats . So it hardly worth worrying about . I'm starting to wonder though if the STR tune is more resilient to the sports cats than the XJR?
Old Oct 29, 2016 | 12:59 AM
  #205
Cambo's Avatar
I don't see how it could be, the factory file that get's loaded into the ECU is exactly the same for the XJR & STR, exact same file.
Unless it's something to do with the emissions settings, perhaps the FED (USA) emissions settings are more picky about the Catalyst Efficiency than the Euro3 which is loaded in the UK-spec cars.
Old Oct 29, 2016 | 03:06 AM
  #206
Datsports's Avatar
Could be somthing in that mine is ex Japan .
How long does it normally take two flag a MIL for cats ?
I thought if it was going to it would have by now ,
Also don't want to speak to soon .
Mine is monitoring 8 items
And I'm certain one of the is catalytic converters.
Old Oct 29, 2016 | 06:57 AM
  #207
JagV8's Avatar
Varies but why not read the pending code?
Old Oct 29, 2016 | 12:57 PM
  #208
jackra_1's Avatar
Default P0174
1st 230 miles driving from MD to MA no problems even a couple of wot runs.
Stopped to fill up with gas. As soon as I started the engine "Restricted Performance" shows up along with orange engine icon.
Driving was ok like that tho.
This morning I read and cleared just the one code P0174 no other codes.
Drove a few miles to get shopping no problem. On the way back tries a wot run and the engine stumbled really badly and again "Restricted Performance".
Why only one bank ?
Not feeling too good about these 200 cel cats to say the least. I am running without the mini cats.
Oh on a good wot run in that 1st 230 miles I could actually see smoke out the back lit up by a cars headlights. Quite a bit.
Old Oct 29, 2016 | 01:31 PM
  #209
alecescolme's Avatar
Sorry to hear your problems...
P0174 is running lean on one bank, the cats shouldn't cause this. The cats should bring up a P0420 'Catalyst Efficiency' code.
Old Oct 29, 2016 | 02:24 PM
  #210
jackra_1's Avatar
Could it be an O2 sensor. Maybe I should swap the lhs ones to the rhs and see whether the fault follows?
I was not having a problem before switching the cats.
Old Oct 29, 2016 | 02:53 PM
  #211
Could be the lambda sensors, yes maybe you could try swapping them over.
Old Oct 29, 2016 | 04:03 PM
  #212
Datsports's Avatar
Bugga , It could also be an exhaust flange leak just above the cat , seen as thay have been disturbed . I'd be checking there ,
Old Oct 29, 2016 | 04:06 PM
  #213
Datsports's Avatar
I have read the pending code , it's p1111
Old Oct 30, 2016 | 07:26 AM
  #214
jackra_1's Avatar
Good point. I used a "non standard" stud on one flange due to a cross threaded nut. I have one on order.
So in a couple of weeks will 1st try redoing both flanges after that if there is still an error swap sensors and go from there.
I am in MA and do not have the ramps etc. that are down in MD.
Old Oct 30, 2016 | 09:30 AM
  #215
JagV8's Avatar
Maybe a badly-fitting cat letting in air thus the P0174.
Old Oct 30, 2016 | 11:44 AM
  #216
jackra_1's Avatar
Problem solved. Just did several wot runs and spun the wheels even in a rolling start.
I remembered the check engine lite coming on after I fitted an oil catch can to the high load side because of a leak.
So I took it out.
No problems now.
So much ado about nothing in the end.
Just cannot get a good seal into the high load breather pipe and I do not want to damage it.
Old Oct 31, 2016 | 06:52 AM
  #217
viper1996's Avatar
Good to hear Jackra...Do you notice a difference in power?
Old Oct 31, 2016 | 06:58 AM
  #218
jackra_1's Avatar
Very noticeable increase in power. Wheel spin like never before even after a long rolling start.
Old Oct 31, 2016 | 07:21 AM
  #219
viper1996's Avatar
I bet your quest to 450 HP is getting close! Intake 10, pulley 15, cats 20, misc. cooling improvements Add Cambo's tune and your there or more!
Old Oct 31, 2016 | 08:00 AM
  #220
jackra_1's Avatar
I think adding the 200 cel cats "enabled" the previous mods I made.
