Radio problems - 2005 XJ8 L
Subscribe
Nov 10, 2021 | 11:41 AM
Hello everyone, I'm new to owning a Jaguar as well as posting in forums. Hopefully I can find some answers on here. Here is the problem; When my car is just turned on (ACC) the FM frequencies pick up fine and is clear as day. When my car is cranked all I hear is static and it doesn't pick up any stations. The CD players plays music, and my FM transmitter works fine when the car is on (ACC). That being said I know the speakers are fine and I know the antenna is fine. Honestly I can't even find the antenna on this car to even check it. What else could it be? Any answers or suggestions are much appreciated. I will respond back to anyone as quick as I can. Thank you.
Reply 0
Nov 10, 2021 | 07:10 PM
Just a guess but the purpose, as I understand it, of the ignition capacitor is to prevent radio interference... perhaps that has gone bad?
Reply 0
Nov 11, 2021 | 06:10 AM
So I did figure out that the rear defroster causes interference. When it is on the radio is static, when it is off radio is clear.
Reply 0
Nov 11, 2021 | 09:20 AM
Hey, my radio also has interference when the rear defrost is on, I just did some searching and found a few things:
- check the side panel in the trunk where the antenna is located and inspect wiring.
- another post mentioned that there could previously have been a sirius/xm radio installed and switched the antenna output to that. My car did come with a sirius unit attached to the dash when I got it so I'm going to check now.
Reply 0
Nov 11, 2021 | 02:10 PM
Also, it seems the FM transmitter causes issues on some of my FM stations. If i unplug it, the stations are clear of static. Try it.
Reply 0
Nov 11, 2021 | 08:56 PM
Cory,
Good sleuthing!
- The AM/FM antenna signal amplifier is right next to rear window heating grid/connector, under LH "C" pillar cover
- Sounds like loose/bad connector there, or grounding point for rear defrost and/or signal amplifier
Reply 0
Subscribe
Currently Active Users (1)
