Random dead battery
Old Nov 4, 2019 | 07:23 AM
Robert Laughton's Avatar
Default Random dead battery
2005 XJR
It's weird......
The car will start normally for a week or two, then randomly the battery is dead.
I carefully check that there're are no lights on, door ajar, glovebox closed etc.
I put in the new battery - same thing.
It seems the car has a random battery draw that starts on its own.
Any ideas where to start?
Thanks all,
Rob
Old Nov 4, 2019 | 07:33 AM
I see from a post below that an open diode in the alternator could cause this. Is there a test for this, or just replace the item and see?
Rob
Old Nov 4, 2019 | 10:27 AM
abonano's Avatar
Also check the flap in the ignition switch. Spray a bit of grease in there. A tiny bit and do not stick the tube in the flap.
Hold it open w/ a tiny screwdriver or pic. Then work the grease in and out with the key.
Old Nov 4, 2019 | 12:36 PM
Wingrider's Avatar
Open alternator diode, will not let the battery discharge, with the negative battery cable disconnected.
Old Nov 6, 2019 | 05:20 AM
Thank you all,
Rob
Old Nov 9, 2019 | 12:13 PM
ChrisMills's Avatar
What about a random intermittent starter motor. I've had one pack up intermittently before it went out completely (not a Jag :-) ) That's why AA Rescue hit them with a long pole, which of course never worked for me. (The Professionals! I Love It)
(the theory being that nudging a brush at the end of it's life just might get it to work)
What about not charging. Car would run for a while. The manual shows a battery symbol for charging indicator, though my X358 only seems to have a red light above the message centre (speedo).
Call me paranoid, but one of these is cheap, easy to understand, and indicates battery charging or state.
https://www.banggood.com/Auto-Car-12...r_warehouse=CN
(Jag) approx 14.5v dropping to 13.5v after 5mins from startup.
at rest, ~12.6v would be a full battery, 12.2v would be 1/2 charged.
If your car is not a daily driver, everyone (I claim to speak for everyone) says you should keep it on a trickle charger.
Please let us know what you find eventually. BTW, if you bought a new battery and accidentally ran it flat, it will now be damaged (less capacity) though not necessarily a write-off depending on how long it was left flat.
Old Nov 9, 2019 | 01:22 PM
Wingrider's Avatar
Starter can draw the battery down, it also has a constant hot, just not quite as likely.
LoveHerTopless
Feb 8, 2018 11:47 PM
alclarkey
Oct 29, 2015 08:57 PM
avioni
Nov 16, 2013 12:00 PM
beema7453
Oct 24, 2013 04:37 PM
Qgregg
May 2, 2012 07:42 PM
