Re-torque intake manifold bolts
Old Feb 4, 2019 | 04:38 PM
thomash85715's Avatar
Default Re-torque intake manifold bolts
HI: I searched in vain for anything about this topic so asking everyone. I saw the smoke test myself and the interface between the #1 (front RH) intake to head leaks. The shop who did this tells me this is cause of lean codes and CEL. Seems logical to me but they want to R&R the manifold and put new gaskets on. Then they cautioned that if manifold is cracked or warped, gaskets will not fix it. New one is $1500 while "guaranteed" ebay ones are $125. If I could learn the torque wrench setting, I might be inclined to reseat those big bolts to prescribed number and see what happens. Am I the only person wondering this or has anyone tried it already and succeeded or failed? The car has 131K on it and had also sprung vacuum leak at EGR. And I do mean the actual EGR itself, not the interface to the intake. My fuel trims are better than I have ever seen them with new EGR but still drift to the rich at low Rs. I assume this is due to O2 sensors telling ECU to push more gas to get right stoichiometry. Thank you.
Old Feb 4, 2019 | 04:49 PM
a4500435's Avatar
This is probably what you're looking for, from pg 569 of the Powertrain section of the Workshop Manual.
Go here, scroll down to Workshop Manual and download all 6 PDFs, it's mandatory. Even if you don't touch a wrench, it's better to have an idea of what the procedures are.
Old Feb 4, 2019 | 06:29 PM
Sean W's Avatar
Please list the codes
Old Feb 4, 2019 | 06:59 PM
NBCat's Avatar
If the manifold is removed to install new gaskets, the return hoses to the EGR/throttle body should also be replaced.
ltshaneclarke
Oct 23, 2018 06:24 PM
J_C_R
Apr 4, 2016 07:38 PM
REDTYPE
Sep 28, 2015 12:08 AM
noterman
Dec 10, 2014 12:17 PM
WaterDragon
Sep 21, 2012 12:15 PM
